sip-ua question
anthonyfear
Hi All
I could use some help setting up CM with my sip-provider.
I've setup sip-ua to connect to and authorise with my sip provider. I have setup my first handset with secondary number (same as username provided by my sip providers) and used the no-reg primary option.
Everything is working fine incoming and outgoing.
My problem is how to add more handsets. As they each need a separate username and password to register with the sip provider.
I tried adding credentials i.e. username 1301 password abcd, username 1302 password abcd etc. under sip-ua and this allows the handsets to register correctly and to receive incoming but now outgoing calls no longer work. If I remove the other registrations so only one handset registers then all handsets can make outgoing calls but only one can receive them.
I believe that using pots dial-peers to do the registrations may help but don't know how to do it.
Any help much appreciated.
Anthony
5 Replies 5
Thanks for the link - it confirms that my config is along the right lines - but the thread is not resolved either.
please send IOS version, configuration for when the problem occours, and a trace with "term mon" and "debug ccsip message".
with sip-ua configured as such:
sip-ua
authentication username 1307 password xxxx
no remote-party-id
registrar ipv4:x.x.x.x expires 3600
sip-server ipv4:x.x.x.x
and a dial-peer :
dial-peer voice 100 voip
translation-profile outgoing PSTN_Outgoing
destination-pattern 9T
session protocol sipv2
session target ipv4:x.x.x.x
session transport udp
dtmf-relay rtp-nte sip-notify
no vad
all extentions are able to call out. However only the one extention (1307) is able to receive direct dial.
So under sip-ua, I tried adding
credentials username 1308 password xxxx realm xxx
however as soon as do that - I can see both extentions register with my itsp but no extentions are able to call out using the above dial-peer but direct dial works to both the numbers.
IOS 124-9.T1
can you try adding realm to authentication ?
Failing that, can you upgrade to 12.4(11)XJ3 ?
Failing that, please send output of "debug ccsip mesage" when placing a SIP call.
