Sip-ua registration peer -1?
breeze_intonate
Hi experts,
I'm playing with the sip side of the voice at the moment, and I'm having trouble with outgoing calls to the sip provider.
while examing the show sip-ua register status command, I found the  88820xxxxxentry, which is the sip provider account name, has the peer value -1, it this normal? I can't find any document regardging to this and also for some reason, all my ISDN (pots)  dial-peers and internal ephone-dns are listed as well?
Thanks in advance for any thoughts.
Cheers,
Leon
Line                       peer expires(sec) registered P-Associ-URI
00[2,3,4,7,8]........ 1002 23 no
013[1-9]...             1004 59 no
01[3,8]00......        1003 0 no
0[2-9].......             1001 0 no
200                       20001 10 no
201                       20002 10 no
202                       20007 10 no
203                       20003 10 no
204                       20004 10 no
205                       20005 10 no
206                       20006 10 no
210                       20008 10 no
688                       20010 10 no
88820xxxxx          -1 81 yes
Manish Gogna
Yes, the peer value of -1 for SIP Trunk is normal, you may check the following post
https://supportforums.cisco.com/discussion/12514431/result-show-sip-ua-register-status-will-be-changed-no-if-sip-trunk-not-reachable
For any outbound call issues you may post the running config and debug ccsip messages for a test call.
Manish
Manish Gogna
Manish
Hi Manish,
Thanks for cleaing the meaning of -1.
I've managed to fix the outgoing call issue, it is due to the internal ephone number been passed on as the "calling" number hence the ISP is refusing it.
Thanks again.
Cheers,
Leon
Hi Leon,
Thanks for updating the post with the resolution.
Manish
