SIP URI Routing
I am doing some lab practice, and I can't get SIP URI routing working from UCM to CME. I have a SIP route pattern and a SIP trunk. The SIP trunk is pointed at the Trunk directly, not through a route group. When I use DNA, it forces me to put "sip:" in front of the SIP dial pattern, but it finds the route pattern when I do that and says that it should route correctly. I have trying using "3001@cme.com" or "sip:3001@cme.com" in the user phone number field, but it fails in the same manner. It isn't sending the traffic to the SIP trunk. I have changed the SIP security profile to use UDP to send to the CME box. I even added a numeric pattern that points at the SIP trunk, and that works. The CME box show no output at all from a "debug ccsip mess" when I attempt to dial from the directory. I have dialed from both a 7971 and a 7941 with the same result. What I see in the SDI logs is as follows:
05/19/2013 16:28:57.713 CCM|StationInit: (0000010) EnblocCall calledParty=3001@cme.com.|<CLID::StandAloneCluster><NID::10.10.210.11><CT::2,100,37,1.1639><IP::10.10.200.126><DEV::SEP00187360892F><LVL::State Transition><MASK::0020>
05/19/2013 16:28:57.713 CCM|StationD:    (0000010) StopTone.|<CLID::StandAloneCluster><NID::10.10.210.11><CT::2,100,37,1.1639><IP::10.10.200.126><DEV::SEP00187360892F><LVL::State Transition><MASK::0020>
05/19/2013 16:28:57.713 CCM|StationD:    (0000010) SelectSoftKeys instance=1 reference=40154599 softKeySetIndex=6 validKeyMask=ffffffff.|<CLID::StandAloneCluster><NID::10.10.210.11><CT::2,100,37,1.1639><IP::10.10.200.126><DEV::SEP00187360892F><LVL::State Transition><MASK::0020>
05/19/2013 16:28:57.713 CCM|Digit Analysis: wait_DaReq: daReq.partitionSearchSpace(:53cdcaac-7d62-0ffb-d223-fa3e96ecd7f4), filteredPartitionSearchSpaceString(INTERNAL), partitionSearchSpaceString(INTERNAL)|<CLID::StandAloneCluster><NID::10.10.210.11><CT::2,100,37,1.1639><IP::10.10.200.126><DEV::SEP00187360892F><LVL::Detailed><MASK::0800>
05/19/2013 16:28:57.713 CCM|Digit Analysis: wait_DaReq: Matching Legacy Numeric, digits=3001@cme.com|<CLID::StandAloneCluster><NID::10.10.210.11><CT::2,100,37,1.1639><IP::10.10.200.126><DEV::SEP00187360892F><LVL::Arbitrary><MASK::0800>
05/19/2013 16:28:57.714 CCM|Digit analysis: wait_DaReq - cepn=[] BlockFlag=[1]|<CLID::StandAloneCluster><NID::10.10.210.11><CT::2,100,37,1.1639><IP::10.10.200.126><DEV::SEP00187360892F><LVL::Arbitrary><MASK::0800>
05/19/2013 16:28:57.714 CCM|Digit Analysis: getDaRes - voiceMailCallingSearchSpace=[]|<CLID::StandAloneCluster><NID::10.10.210.11><CT::2,100,37,1.1639><IP::10.10.200.126><DEV::SEP00187360892F><LVL::State Transition><MASK::0800>
05/19/2013 16:28:57.714 CCM|Digit analysis: match(pi="2",fqcn="1024", cn="1024", plv="5", pss="INTERNAL", TodFilteredPss="INTERNAL", dd="3001@cme.com",dac="0")|<CLID::StandAloneCluster><NID::10.10.210.11><CT::2,100,37,1.1639><IP::10.10.200.126><DEV::SEP00187360892F><LVL::Detailed><MASK::0800>
05/19/2013 16:28:57.714 CCM|Digit analysis: potentialMatches=NoPotentialMatchesExist|<CLID::StandAloneCluster><NID::10.10.210.11><CT::2,100,37,1.1639><IP::10.10.200.126><DEV::SEP00187360892F><LVL::Detailed><MASK::0800>
05/19/2013 16:28:57.714 CCM|StationD:    (0000010) StopTone.|<CLID::StandAloneCluster><NID::10.10.210.11><CT::2,100,37,1.1639><IP::10.10.200.126><DEV::SEP00187360892F><LVL::State Transition><MASK::0020>
I can't quite tell what is blocking this, but it never makes it to CME. What am I missing? I know I have done this before, and it is driving me nuts!
0 Replies 0
