CME with SIP Trunk
alap84
Hi Experts
i am facing problem when calling outside using my SIP trunk from ITSP. i am calling from my gateway using csim start number it shows folloing messages
csim start 38880951
May 18 16:57:58.887: csim: called number = 38880951, loop count = 1 ping count =
May 18 16:57:58.887: csimSetupPeer peer type(2), destPat(38880951), matched(0),
target()
May 18 16:57:58.887: //-1/xxxxxxxxxxxx/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=FALSE, Mode=0,
   Outgoing Dial-peer=100, Params=0x4B67766C, Progress Indication=NULL(0)
May 18 16:57:58.887: //-1/xxxxxxxxxxxx/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Present
ation=Allowed)
   Out: Calling Number=13666667(TON=Unknown, NPI=ISDN, Screening=Network, Presen
tation=Allowed)
   Destination Pattern=.T, Called Number=38880951, Digit Strip=FALSE
fakhro#lSetupRequest:
   Calling Number=13666667(TON=Unknown, NPI=ISDN, Screening=Network, Presentatio
n=Allowed),
   Called Number=38880951(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=FALSE,
   Guid=ED774BF1-BF12-11E2-888F-A62C964BFFF3, Outgoing Dial-peer=100
May 18 16:57:58.887: //-1/xxxxxxxxxxxx/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=13666667
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=38880951
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
May 18 16:57:58.887: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x48B01490, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=13666667,(Calling Name=)(TON=Unknown, NPI=ISDN, Sc
reening=Network, Presentation=Allowed),
   Called Number=38880951(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=100, Cal
l Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Appl
ication Call Id=)
May 18 16:57:58.887: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 18 16:57:58.887: :cc_get_feature_vsa malloc success
May 18 16:57:58.887:  cc_get_feature_vsa count is 1
May 18 16:57:58.887: :FEATURE_VSA attributes are: feature_name:0,feature_time:12
66272040,feature_id:454
May 18 16:57:58.891: //6427/ED774BF1888F/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
May 18 16:57:58.891: //6427/ED774BF1888F/CCAPI/ccCallSetContext:
   Context=0x47DB8150
May 18 16:57:58.891: //6427/ED774BF1888F/CCAPI/cc_api_call_proceeding:
   Interface=0x48B01490, Progress Indication=NULL(0)
May 18 16:57:58.891: csim_do_test: cid(6427), ev(22), disp(0)
May 18 16:57:58.891: csimTraceSct: cid(6427),st(0),oldst(0)
May 18 16:57:58.891: csimIgnore  cid(6427), st(0),oldst(0), ev(22)
May 18 16:57:58.895: //6427/ED774BF1888F/CCAPI/cc_api_call_disconnected:
   Cause Value=47, Interface=0x48B01490, Call Id=6427
   Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
May 18 16:57:58.895: csim_do_test: cid(6427), ev(12), disp(0)
May 18 16:57:58.895: csimTraceSct: cid(6427),st(0),oldst(0)
May 18 16:57:58.895: csim err csimDisconnected recvd DISC cid(6427)
May 18 16:57:58.895: //6427/ED774BF1888F/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C
ause=47)
   Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
May 18 16:57:58.895: //6427/ED774BF1888F/CCAPI/cc_api_call_disconnect_done:
   Disposition=-11, Interface=0x48B01490, Tag=0x0, Call Id=6427,
   Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
May 18 16:57:58.895: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 18 16:57:58.895: :cc_free_feature_vsa freeing 4B79C720
May 18 16:57:58.899: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 18 16:57:58.899:  vsacount in free is 0
May 18 16:57:58.899: //6427/ED774BF1888F/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x4B78DA84
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 13666667
Called Number            : 38880951
Source IP Address (Sig  ): 172.26.2.58
Destn SIP Req Addr:Port  : :5060
Destn SIP Resp Addr:Port : :5060
Destination Name         : voice.server.com
Disconnect Cause (CC)    : 47
Disconnect Cause (SIP)   : 200
May 18 16:57:58.899: csim_do_test: cid(6427), ev(13), disp(-11)
May 18 16:57:58.899: csimTraceSct: cid(6427),st(2),oldst(0)
May 18 16:57:59.399: csim: loop = 1, failed = 1
May 18 16:57:59.399: csim: call attempted = 1, setup failed = 1, tone failed = 0
May 18 16:57:59.399: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
   ccAppShutdownMode: remove it from the queue
2 Accepted Solutions
Never use "csim start" as a troubleshooting method, it is unreliable, if you want to address the problem, you better use real phone, and make test calls. It is an advise from my troubleshooting experience
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
absolutely..Jorge spot on. I hate that command as unreliable as anything..
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
7 Replies 7
Ayodeji Okanlawon
You are getting a cause code of 47.which usually points to a capability issue. Can you send a sh run. Can you also do another test call with a phone and send debug ccsip messages and debug voip ccapi inout
hi bro ...
at this moment i cant do the call from hardphone
Current configuration : 10290 bytes
version 12.4
hostname fakhro
boot-start-marker
boot system flash c2800nm-adventerprisek9-mz.124-24.T8.bin
boot-end-marker
logging message-counter syslog
logging buffered 52000
enable secret
no aaa new-model
clock timezone UTC 3
network-clock-participate wic 1
dot11 syslog
ip source-route
ip cef
ip domain lookup source-interface GigabitEthernet0/1.2374
ip name-server x.x.x.x
no ipv6 cef
isdn switch-type primary-net5
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
supplementary-service h450.12
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/1.2374
  bind media source-interface GigabitEthernet0/1.2374
  header-passing
  error-passthru
  registrar server expires max 250 min 200
  early-offer forced
voice class codec 99
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711alaw
voice translation-rule 900
rule 1 /^550/ /13699550/
rule 2 /^551/ /13699551/
rule 3 /^552/ /13699552/
rule 4 /^553/ /13699553/
rule 5 /^554/ /13699554/
rule 6 /^558/ /13699558/
voice translation-rule 901
rule 1 /^13699550$/ /550/
rule 2 /^13699551$/ /551/
rule 3 /^13699552$/ /552/
rule 4 /^13699553$/ /553/
rule 5 /^13699554$/ /554/
rule 6 /^13699558$/ /558/
voice translation-rule 920
rule 1 /^9/ //
voice translation-profile 900-Incoming
translate calling 901
translate called 901
voice translation-profile Add-13699
translate calling 900
translate called 920
voice translation-profile block
translate called 987
voice translation-profile test
translate called 910
voice-card 0
fax interface-type fax-mail
crypto pki trustpoint TP-self-signed-289312270
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-289312270
revocation-check none
rsakeypair TP-self-signed-289312270
crypto pki certificate chain TP-self-signed-289312270
certificate self-signed 02
  30820247 308201B0 A0030201 02020102 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32383933 31323237 30301E17 0D313330 35303930 37343535
  325A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3238 39333132
  32373030 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  E4069769 9B047A5C 5F97F82F C71AAA58 BDA620AB CB97CA2B 1001F16F 733C928B
  CFABD8E2 2E567FCB 74940E22 24E556D5 63F4633F 7233E71E FF66763A 62D65BE6
  73CBD340 C76D4213 1A51D343 C06E64F0 2418FBC5 8C785D8E 2AE76906 3250E22A
  3B78EA20 CCD1A691 CB4AFE89 7401D0B3 842FBB5D A7949301 6ADD574E F4D67215
  02030100 01A37130 6F300F06 03551D13 0101FF04 05300301 01FF301C 0603551D
  11041530 13821166 616B6872 6F2E6661 6B68726F 2E636F6D 301F0603 551D2304
  18301680 14F9AB29 D697552C 412C9422 B60F333C 281B7256 D3301D06 03551D0E
  04160414 F9AB29D6 97552C41 2C9422B6 0F333C28 1B7256D3 300D0609 2A864886
  F70D0101 04050003 8181007E 6FCE2BB0 B37FB086 493FDDBA CA5A1123 57369A0C
  485100B2 7BBB51F8 82A7AE97 A1C2D616 7FE91D44 1EC4925A E7994D25 44DB2D72
  004E6994 72DFC02C 8C501C2C D6C2942A 6E60B4F6 507C70E3 2DAF15F5 0F5F4589
  BA0175D9 B24AB63C 77AEFEB3 5038B431 BC5FA26B 8B748BE9 8A9782BC C6E376C2
  E0F7BAA0 4B33A8B5 911297
        quit
username xxx privilege 15 password 0 xxx
archive
log config
  hidekeys
crypto isakmp policy 2
hash md5
authentication pre-share
crypto isakmp policy 10
encr 3des
hash md5
group 2
crypto isakmp key KCC-BH123 address x.x.x.x
crypto ipsec transform-set ASA-IPSEC esp-des esp-sha-hmac
crypto ipsec transform-set KCC esp-3des esp-md5-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to x.x.x.x
set peer x.x.x.x
set transform-set KCC
set pfs group2
match address 100
qos pre-classify
controller E1 0/1/0
framing NO-CRC4
translation-rule 1
interface GigabitEthernet0/0
description *** lAN Interface ***
ip address 10.190.10.2 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.2373
description ***  Internet 1Mb ***
encapsulation dot1Q 2373
ip address x.x.x.x x.x.x.x
ip nat outside
description *** VOIP Link 1280 Kbps ***
encapsulation dot1Q 2374
ip address 172.26.2.58 255.255.255.252
interface FastEthernet0/0/0
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Vlan1
description $ES_LAN$
no ip address
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 x.x.x.x
ip route 172.26.0.0 255.255.0.0 GigabitEthernet0/1.2374
ip http server
ip http authentication local
ip http secure-server
ip nat inside source route-map SDM_RMAP_1 interface GigabitEthernet0/1.2373 overload
access-list 1 remark SDM_ACL Category=16
access-list 1 permit 10.190.10.0 0.0.0.255
access-list 100 remark SDM_ACL Category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip 10.190.10.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 100 permit ip 10.190.10.0 0.0.0.255 192.168.0.0 0.0.255.255
route-map SDM_RMAP_1 permit 1
match ip address 101
tftp-server flash:apps37sccp.1-2-1-0.tar
tftp-server flash:CP7902080002SCCP060817A.sbin
tftp-server flash:CP7905080002SCCP060817A.sbin
tftp-server flash:term11.default.loads
tftp-server flash:B015-1-0-3.SBN
tftp-server flash:B016-1-0-3.SBN
tftp-server flash:apps11.8-4-1-23.sbn
tftp-server flash:cnu11.8-4-1-23.sbn
tftp-server flash:cvm11sccp.8-4-1-23.sbn
tftp-server flash:dsp11.8-4-1-23.sbn
tftp-server flash:jar11sccp.8-4-1-23.sbn
tftp-server flash:SCCP11.8-4-2S.loads
tftp-server flash:term06.default.loads
control-plane
sccp ccm group 1
dspfarm profile 10 conference
maximum conference-participants 0
dial-peer voice 100 voip
tone ringback alert-no-PI
translation-profile incoming 900-Incoming
translation-profile outgoing Add-13699
destination-pattern .T
session protocol sipv2
session target dns:voice.bb.zain.com
dtmf-relay sip-kpml sip-notify
no fax-relay sg3-to-g3
clid network-number 13666667
no vad
dial-peer voice 101 voip
voice-class codec 99
session target sip-server
incoming called-number .T
dtmf-relay sip-notify sip-kpml
sip-ua
credentials username xxxxxxx password 7 xxxxxxx realm voice.server.com
retry options 1
registrar dns:voice.server.com:5060 expires 1800
sip-server dns:voice.server.com:5060
permit hostname dns:voice.server.com
telephony-service
authentication credential name name
em keep-history
xml user namer password name 15
max-ephones 110
max-dn 288
ip source-address 10.190.10.2 port 2000
service phone webAccess 0
timeouts interdigit 3
timeouts ringing 20
system message message
url services http://10.190.10.2/voiceview/common/login.do
url authentication http://10.190.10.2/CCMIP/authenticate.asp
load 7911 SCCP11.8-4-2S
time-zone 31
max-conferences 8 gain -6
web admin system name name password passowrd
dn-webedit
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp 7960 May 17 2013 15:13:16
ephone-dn  1
number 550 no-reg both
description Test
name Test
ephone-dn  2
number 551 no-reg primary
description
name
ephone-dn  3
number 552 no-reg primary
description
name
ephone-dn  4
number 553
description
name
ephone-dn  5
number 554
description
name
ephone-dn  6
number 558
description
name
ephone  1
device-security-mode none
mac-address 0023.EBC8.7818
type 7911
button  1:1
ephone  2
mac-address 0023.EBC8.756E
type 7911
button  1:2
ephone  3
mac-address 0023.EBC8.7281
type 7911
button  1:3
ephone  4
mac-address 0023.EBC8.DDCE
type 7911
button  1:4
ephone  5
mac-address 0023.EBC8.E655
type 7911
button  1:5
ephone  6
mac-address 0023.EBC8.7372
type 7911
button  1:6
ephone  7
line con 0
line aux 0
csim start 36613334
May 18 23:07:48.845: csim: called number = 36613334, loop count = 1 ping count =
May 18 23:07:48.845: csimSetupPeer peer type(2), destPat(36613334), matched(0),
target()
May 18 23:07:48.845: //-1/xxxxxxxxxxxx/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=100, Params=0x4B766AC4, Progress Indication=NULL(0)
May 18 23:07:48.845: //-1/xxxxxxxxxxxx/CCAPI/ccCheckClipClir:
ation=Allowed)
May 18
fakhro#23:07:48.845: //-1/xxxxxxxxxxxx/CCAPI/ccCheckClipClir:
tation=Allowed)
   Destination Pattern=.T, Called Number=36613334, Digit Strip=FALSE
n=Allowed),
   Called Number=36613334(TON=Unknown, NPI=Unknown),
   Guid=97B64097-BF46-11E2-89C0-A62C964BFFF3, Outgoing Dial-peer=100
May 18 23:07:48.845: //-1/xxxxxxxxxxxx/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=13666667
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=36613334
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
May 18 23:07:48.845: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Called Number=36613334(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
l Count On=FALSE,
ication Call Id=)
May 18 23:07:48.845: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 18 23:07:48.845: :cc_get_feature_vsa malloc success
May 18 23:07:48.845:  cc_get_feature_vsa count is 1
May 18 23:07:48.845: :FEATURE_VSA attributes are: feature_name:0,feature_time:12
66651352,feature_id:533
May 18 23:07:48.845: //6971/97B6409789C0/CCAPI/ccIFCallSetupRequestPrivate:
May 18 23:07:48.845: //6971/97B6409789C0/CCAPI/ccCallSetContext:
   Context=0x47DB8200
May 18 23:07:48.849: //6971/97B6409789C0/CCAPI/cc_api_call_proceeding:
May 18 23:07:48.849: csim_do_test: cid(6971), ev(22), disp(0)
May 18 23:07:48.849: csimTraceSct: cid(6971),st(0),oldst(0)
May 18 23:07:48.849: csimIgnore  cid(6971), st(0),oldst(0), ev(22)
May 18 23:07:48.853: //6971/97B6409789C0/CCAPI/cc_api_call_disconnected:
   Cause Value=47, Interface=0x48B01490, Call Id=6971
May 18 23:07:48.853: csim_do_test: cid(6971), ev(12), disp(0)
May 18 23:07:48.853: csimTraceSct: cid(6971),st(0),oldst(0)
May 18 23:07:48.853: csim err csimDisconnected recvd DISC cid(6971)
May 18 23:07:48.853: //6971/97B6409789C0/CCAPI/ccCallDisconnect:
ause=47)
May 18 23:07:48.853: //6971/97B6409789C0/CCAPI/cc_api_call_disconnect_done:
   Disposition=-11, Interface=0x48B01490, Tag=0x0, Call Id=6971,
May 18 23:07:48.853: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 18 23:07:48.853: :cc_free_feature_vsa freeing 4B7F90D0
May 18 23:07:48.853:  vsacount in free is 0
May 18 23:07:48.853: csim_do_test: cid(6971), ev(13), disp(-11)
May 18 23:07:48.853: csimTraceSct: cid(6971),st(2),oldst(0)
May 18 23:07:49.353: csim: loop = 1, failed = 1
May 18 23:07:49.353: csim: call attempted = 1, setup failed = 1, tone failed = 0
May 18 23:07:49.353: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
Please capture:
deb voice ccapi inout
deb ccsip messages
Those debugs will give us a better idea of the issue.
Please avoid using the same pattern for incoming and outgoing calls, it can cause call routing loops:
destination-pattern .T <-----------------------------
no vad
incoming called-number .T <-----------------------------
Please use something more specific to match outgoing calls.
Jorge Armijo
is that ok ?
destination-pattern [1,3,8,9].......
session transport udp
no vad
deb ccsip messages
router#csim start 36613334
May 18 23:50:47.289: csim: called number = 36613334, loop count = 1 ping count =
May 18 23:50:47.289: csimSetupPeer peer type(2), destPat(36613334), matched(1),
target()
May 18 23:50:47.289: //-1/xxxxxxxxxxxx/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=100, Params=0x4B792D60, Progress Indication=NULL(0)
May 18 23:50:47.289: //-1/xxxxxxxxxxxx/CCAPI/ccCheckClipClir:
ation=Allowed)
tation=Allowed)
   Destination Pattern=[1,3,8,9]......., Called Number=36613334, Digit Strip=FAL
SE
n=Allowed),
   Guid=98958FEA-BF4C-11E2-89CC-A62C964BFFF3, Outgoing Dial-peer=100
May 18 23:50:47.289: //-1/xxxxxxxxxxxx/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=13666667
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=36613334
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
May 18 23:50:47.293: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
l Count On=FALSE,
ication Call Id=)
May 18 23:50:47.293: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 18 23:50:47.293: :cc_get_feature_vsa malloc success
May 18 23:50:47.293:  cc_get_feature_vsa count is 1
May 18 23:50:47.293: :FEATURE_VSA attributes are: feature_name:0,feature_time:12
66699104,feature_id:536
May 18 23:50:47.293: //6988/98958FEA89CC/CCAPI/ccIFCallSetupRequestPrivate:
May 18 23:50:47.293: //6988/98958FEA89CC/CCAPI/ccCallSetContext:
   Context=0x47DB95F0
May 18 23:50:47.293: //6988/98958FEA89CC/CCAPI/cc_api_call_proceeding:
May 18 23:50:47.293: csim_do_test: cid(6988), ev(22), disp(0)
May 18 23:50:47.293: csimTraceSct: cid(6988),st(0),oldst(0)
May 18 23:50:47.293: csimIgnore  cid(6988), st(0),oldst(0), ev(22)
May 18 23:50:47.301: //6988/98958FEA89CC/CCAPI/cc_api_call_disconnected:
   Cause Value=47, Interface=0x48B01490, Call Id=6988
May 18 23:50:47.301: csim_do_test: cid(6988), ev(12), disp(0)
May 18 23:50:47.301: csimTraceSct: cid(6988),st(0),oldst(0)
May 18 23:50:47.301: csim err csimDisconnected recvd DISC cid(6988)
May 18 23:50:47.301: //6988/98958FEA89CC/CCAPI/ccCallDisconnect:
ause=47)
May 18 23:50:47.301: //6988/98958FEA89CC/CCAPI/cc_api_call_disconnect_done:
   Disposition=-11, Interface=0x48B01490, Tag=0x0, Call Id=6988,
May 18 23:50:47.301: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 18 23:50:47.301: :cc_free_feature_vsa freeing 4B804B58
May 18 23:50:47.301:  vsacount in free is 0
May 18 23:50:47.301: csim_do_test: cid(6988), ev(13), disp(-11)
May 18 23:50:47.301: csimTraceSct: cid(6988),st(2),oldst(0)
May 18 23:50:47.801: csim: loop = 1, failed = 1
May 18 23:50:47.801: csim: call attempted = 1, setup failed = 1, tone failed = 0
May 18 23:50:47.801: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
Jorge Armijo
HI Experts ....
absolutely right ... never trust on this command ... all was working ..... this command only give me headache ...
