Slip Errors on T1 Controller
waltzy
T1 Contollers on MGCP 3945 gateway accumulating Slip errors.  We have three PRI's inbound/outbound with the first set at clock source line primary.  We are experiencing problems with faxes not completed.  Fax machine's report line error and disconnect.   I think its a clocking issue but haven't had any luck.  Any suggestions
do network-clock-select 1 T1 0/0/0 and it will fix it...
Cheers,
Chad
5 Replies 5
Chad Stachowicz
Level 6
Level 6
it is def clocking...
Please post your configuration or no one can help you.
Chad
version 15.0
hostname 3945_Gateway-2
boot-start-marker
boot-end-marker
card type t1 0 0
card type t1 0 1
logging buffered 51200 warnings
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication login console none
aaa authorization exec default group tacacs+ local
aaa authorization exec console none
aaa authorization exec no-tacacs-console none
aaa session-id common
network-clock-participate wic 0
network-clock-participate wic 1
no ipv6 cef
ip source-route
ip cef
ip domain name pct.edu
isdn switch-type primary-ni
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
license udi pid C3900-SPE150/K9 sn FOC14415CKU
hw-module pvdm 0/0
redundancy
controller T1 0/0/0
cablelength long 0db
pri-group timeslots 1-24 service mgcp
controller T1 0/0/1
controller T1 0/1/0
controller T1 0/1/1
ip ssh version 2
interface GigabitEthernet0/0
ip address 10.3.0.246 255.255.0.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/0/1:23
no ip address
encapsulation hdlc
no cdp enable
interface Serial0/1/0:23
no ip address
encapsulation hdlc
no cdp enable
interface Serial0/1/1:23
no ip address
encapsulation hdlc
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.3.1.1
nls resp-timeout 1
cpd cr-id 1
snmp-server community w1ldc4ts RW
snmp-server enable traps tty
tacacs-server host 10.150.0.251
tacacs-server timeout 10
tacacs-server directed-request
tacacs-server key iworkforpct
control-plane
voice-port 0/0/0:23
input gain -2
output attenuation 2
echo-cancel coverage 64
voice-port 0/1/0:23
input gain -2
voice-port 0/0/1:23
input gain -2
voice-port 0/1/1:23
input gain -2
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.3.0.254
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.3.0.254
ccm-manager config
mgcp
mgcp call-agent 10.3.0.253 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp ip qos dscp cs3 signaling
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
gatekeeper
shutdown
line con 0
logging synchronous
login authentication console
line aux 0
line vty 0 4
session-timeout 30
exec-timeout 30 0
privilege level 15
transport input all
line vty 5 15
session-timeout 30
exec-timeout 30 0
privilege level 15
transport input all
scheduler allocate 20000 1000
ntp update-calendar
ntp server 10.133.2.1 prefer source GigabitEthernet0/0
version 15.0
boot-start-marker
boot-end-marker
card type t1 0 0
card type t1 0 1
aaa new-model
Payal Bhaduri
If you have slip errors, it is definitely related to clocking.
You must configure network-clock-participate and network-clock-select commands.
Here are some references:
http://www.cisco.com/en/US/docs/ios/12_3t/voice/command/reference/vrht_n1_ps5207_TSD_Products_Command_Reference_Chapter.html#wp1016893
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00800f99bb.shtml#slipsecs
Cheers,
Chad
Thanks guys.  That fixed the issue.
