Softkey Template - Redial button not appearing
Abhishek Singh
We have around 50 phones - 8941 - issue - the phones even after setting the correct call state and adding the red-dial softkey option in on-hook and off-hook template the , the 8941 phones, do not seem to show the key, even after rebooting the phone several times. Is there a step we are missing or is this some kind of a known issue with the 8941 devices. Can someone give a quick advice on this.
CUCM System version: 8.6.2.21900-5
Whatever level you reach getting better never stops -- Sachin Tendulkar
Rob Huffman
Hi Abhishek,
Here's why this is happening;
The Cisco Unified IP Phones 8941 and 8945 do not support all the softkeys that are configurable in Softkey Template Configuration on Cisco Unified CM Administration. Cisco  Unified Communications Manager allows you to enable or disable some  softkeys in the control policy configuration settings, but the Cisco  Unified IP Phones 8941 and 8945 do not support feature control policy  configuration settings. Table 5-2 lists the features, softkeys that can be configured on a softkey template, and note whether it is supported on the Cisco Unified IP Phones 8941 and 8945.
Note Cisco  Unified Communications Manager allows you to configure any softkey in a  softkey template, but unsupported softkeys do not display on the phone.
Table 5-2     Configurable Softkeys
Feature
Configurable Softkeys in the Softkey Template Configuration
Supported as a softkey on Cisco Unified IP Phone 8941 and 8945
Notes
Answer
Answer (Answer)
Yes
Barge
Barge (Barge)
No
Call Back
Call Back (CallBack)
Yes
Call Forward All
Forward All (cfwdAll)
Yes
Phone displays Fwd ALL or Fwd Off.
Call Park
Call Park (Park)
Yes
Call Pickup
Pick Up (Pickup)
Yes
Conference
Conference (Confrn)
Yes
Conference is a dedicated button.
Only exists on video call.
Conference List
Conference List (ConfList)
Yes
Phone displays Detail.
Divert
Immediate Divert (iDivert)
Yes
Phone displays Divert.
Do Not Disturb
Toggle Do Not Disturb (DND)
Yes
Configure Do Not Disturb as a programmable line button.
End Call
End Call (EndCall)
Yes
Phone displays Cancel if the call is not answered.
Group Pickup
Group Pick UP (GPickUp)
Yes
Hold
Hold (Hold)
No
Hold is a dedicated button.
Hunt Group
HLog (HLog)
Yes
Configure Hunt Group as a programmable feature button.
Join
Join (Join)
No
Malicious Call Identification
Toggle Malicious Call Identification (MCID)
Yes
Configure Malicious Call Identification as a programmable feature button.
Meet Me
Meet Me (MeetMe)
Yes
Mobile Connect
Mobility (Mobility)
Yes
Configure Mobile Connect as a programmable feature button.
New Call
New Call (NewCall)
Yes
Phone displays New Call.
Other Pickup
Other Pickup (oPickup)
Yes
Quality Reporting Tool
Quality Reporting Tool (QRT)
Yes
Configure Quality Reporting Tool as a programmable feature button.
Redial
Redial (Redial)
No
Remove Last Conference Participant
Remove Last Conference Participant (Remove)
Yes
Phone displays Remove when a participant is selected.
Resume
Resume (Resume)
Yes
Select
Select (Select)
No
Speed Dial
Abbreviated Dial (AbbrDial)
Yes
Phone displays SpeedDial.
Transfer
Direct Transfer (DirTrfr)
Yes
Transfer is a dedicated button.
Configure transfer (Direct Transfer policy) in the Product Specific Configuration Layout section in Phone Configuration.
Video Mode Command
Video Mode Command (VidMode)
No
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/8941_8945/8_5/english/admin_guide
/6921usr.html#wp1031287
Cheers!
Rob
"Talk about a dream
Try to make it real"
- Springsteen
Hi Rob,
Thanks, Yes , once i regained some composure , i did go through this..such a shame that a high-end phone can miss something as elementary as that, anyways, thanks as always.. you are THE SAVIOUR
thank you for the guide which explains this.
I can only agree that this is more then poor for such an expensive phone.
A redial button is not presented to the user, but a video softkey to see theirself :-)
Maic Naatz
Hi together,
i am just looking in the user guide for this type of phone. I found, that the phone have a dedicated redial button. So you dont need to have an redial softkey.
Hope this helps.
