softkeys template for 8821 wireless ip phone
STD IN
Hi All, how can I transfer a call from wireless Ip phone 8821 to other extension ?
once I got a call and  pressed the physical button ... but transfer buttons is not appear
even I create sofkey template
voice register template  1
 softkeys idle  Redial Cfwdall DND Newcall Pickup
 softkeys ringIn  Answer DND
 softkeys connected  Endcall Trnsfer Hold Mobility
voice register dn  116
 number 220
voice register pool  1
 id mac 2852.613A.67EA
 session-transport tcp
 type 8821
 number 1 dn 116
 template 1
 dtmf-relay rtp-nte cisco-rtp sip-notify
 username 220 password 22p
 codec g711ulaw
 no vad
voice register global
create profile
whrere I have CME 15.6 , 8821 version 11.0
please advise
Manish Gogna
I have seen a couple of cases where it required setting the reference-pooltype to 8861 or 8945 for this phone model.
You can try and let me know how it goes.
Example:
voice register pool-type  8821
 phoneload-support
 transport tcp
 num-lines 2
 description Cisco SIP Phone 8821
 reference-pooltype 8861
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cuipph/8821/english/Deployment/8821_wlandg.pdf
Manish
Manish Gogna
Example:
 phoneload-support
 transport tcp
 num-lines 2
Manish
Hi Manish, it's working fine
is it same configuration  regarding 8845 or other pool-type ?
Not sure about others, but if you face similar issue then you can give this workaround a try.
Manish
