Software Version license is missing
sachemwxit
when I log in console I found the following warning:
Licensing Warnings:
Software Version license is missing. Call Manager Service will not start. Please upload SW Feature license file.
I didn't do any upgrade, I don't know why this happen, maybe caused by power shutdown ,
I checked the service activation, the "call manager service" is activated,
my CUCM works well now, I can dial and receive calls normally,
will anyone tell me why this happens ? will this cause my CUCM stop working ? and how do I solve this issue ?
thank you very much!
Jaime Valencia
Have you tried deleting your license and uploading it again??
Do you see the license via CLI?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi javalenc,
      thank you for your advice , I will try them and tell you the result as soon as possible!
