Speech Connect Transfers straight to VM not Extension
I have currently setup a DN to forward to Unity then I created the Directory Handler to be voice enabled.
When dialing the number i get the IVR response and say the persons name it finds the person and their extension then it says "Please wait while i transfer you" Then it immediately plays their VM recording. I know these users are not on their phones. Unity some how seems to think they are busy.
Any help would be much appreciated
Jaime Valencia
What are the transfer settings for those users?
java
if this helps, please rate
Status is set to Enabled with no End Date and Time
Transfer calls to their 4 digit extension
Transfer type Release to Switch
Ring to Wait For 4
Play the "Wait While I Transfer Your Call" Prompt is Checked
If extension is busy Send Callers to Voicemail
OK, now, does the call restriction tables and the CUCM-CUC integration allow you to reach those DNs?
java
Made a change in Restriction tables for Default Transfer still getting VM.
I checked the CSS and the DN's trying to be reached are in there.
