IP Telephony and Phones
Labels
Hi, Some of the users in my organization were reporting issues with entering numbers after placing the call users were not able to enter the pin, one common thing that i noticed was all of them had Cisco IP communicator configured with SIP protocol s...
Hi all, I have my gateway with only two (2) interfaces and one E1 port. One interface is used to connect to the network, now I have to add two(2) more E1 sip to my gateway. For this type of topology, what will the best practices be to add connect the...
I am going to use a Cisco 2811 Router as a TFTP Server for ring tones and backgrounds for my phones, I switched the CF Card from 64MB, to 512MB, and now I am unable to install the IOS Image onto the flash, I have tried everything, from different TFTP...
Ian Sully by Level 1
  • 870 Views
  • 9 replies
HI,I have H323 Voice gateway and CUCM 7. Everything is working fine and i can call outside but when i call inside and i press 0 for the operator or any extension then i cant hear and on the other side (extension) no more ring but there is no sound to...
techguy by Level 4
  • 7061 Views
  • 10 replies
Hi We are using CUCM 12.5 with SIP VG. I have added the calling party transformation pattern to prefix 9 for the incoming local calls & assigned the CCS under the "Incoming Calling Party Settings" under the SIP Trunk.  And also created another "calli...
