11-17-2015 11:21 AM - edited 03-17-2019 04:56 AM
My problem is as follows. I have a cisco 7965. My customer would like to program a speed dial to dial a number, and than after the call is
answered, it requires a pin number. He wants to program another speed dial with the pin number, but the phone will not transmit the numbers
when pressed. The problem is with the second speed dial does not work after connecting to call. Any ideas?
11-17-2015 11:26 AM
Is that even possible?
Can you discribe your enviroment, CME, CUCM, UCCX?
Thanks.
Rolando Valenzuela.
11-17-2015 11:35 AM
Not sure if its possible. I am running CUCM 8.6. I am new to Cisco, but my other phone system(Avaya Blue) will allow the speed dial to transmit after connection.
Ernie
11-17-2015 11:57 AM
Grame0001
Well, CME or CUCM I guess is not possible, I was asking for your enviroment, since UCCX can perform a 'send digits' step, and then instead of having two speed-dials, you can have only one and UCCX will do the rest.
You can try and check.
Rolando Valenzuela.
11-17-2015 11:40 AM
a speed dial is a command such as
dial:extension so it cannot be used to send dtmf.
Carlo
11-17-2015 11:45 AM
Thanks for the quick response guys.
Ernie
11-17-2015 11:59 AM
You could probably use this, but you would need to upgrade
https://supportforums.cisco.com/document/126846/pause-speed-dial-cucm-9x
This is not possible with your CUCM version.
11-17-2015 12:21 PM
Thanks for the response Jaime. We are actually upgrading to cucm 10 within the next month, so I will use it after upgrade.
Ernie
