SQL insert blfspeeddial Number to a phone device
mediCH
Hello everyone,
Sometimes I must create a lot of SIP Phone where within I must put in approximatively 36 blfspeeddial numbers and all phones have the same numbers list.
So I was searching for a solution to put in all those numbers with a sql query.
I made this query to list all BLFspeeddial configured in a specific Phone :
run sql SELECT d.pkid, d.name, d.description, blf.blfindex, blf.label, blf.blfdestination FROM blfspeeddial as blf inner join device as d on blf.fkdevice=d.pkid WHERE d.name='SEPxxxxxxxxxxxx'
This one to list all blfspeeddial configured in the system
run sql SELECT * FROM blfspeeddial ORDER BY fkdevice
and now I try to add blfspeeddial on an existing phone but can't find the solution :
I've tried something like this but without result :
Run sql INSERT INTO blfspeeddial (label, fkdevice, blfindex, blfdestination) VALUES ('labeltest', '04ef2694-53c8-35d8-335c-9fedb7d60a62', '2', '12288')
I have low knowledge with sql and I'm new to the CUCM world so I was thinking that someone had the same problem one time, and did find the solution :)
Robin
Brandon Buffin
One option is to use BAT (Bulk Administration Tool). In CUCM go to Bulk Administration > Phones > Update Phones > Query. Enter a query for the phone(s) to be updated. I recommend testing on one phone to start. After you click Next there is an option and the bottom of the screen to assign speed dials using a template.
Brandon
Brandon Buffin
Brandon
Thanks for your answer again,
I will look at that
Robin
I found the template to do that and everything but i have the bugged version of cucm (11.0.1.21900-11) so I need to update it before use this feature.
Thanks for everything ;)
