SRST Auto Attendant without CUE
Mudasir Abbas
I have setup CISCO2921/K9 as SRST & voice gateway. There are few FXOs connected to PSTN.
There is no Voice-Mail module, I am trying to setup Auto Attendant using TCL scripts.
call from outside PSTN to local PSTN numbers (connected on Voice gateway FXOs). it is required to send this call to Auto Attendant and caller will put the user extension.
With my given configs it sends the call to 2100 IP Phone but does not play the audio.
Topology:
|PSTN|------|V-GW|--------|WAN|-------|CUCM|
                  |IP Phone Ext. 2100|
Please see what am I missing ...
VGW#sh flash
-#- --length-- -----date/time------ path
1     62662920 Sep 08 2010 00:21:08 c2900-universalk9-mz.SPA.150-1.M3.bin
8      1008640 Feb 15 2012 09:13:04 cme-b-acd-2.1.0.0.tar
9         8207 Feb 18 2012 07:53:32 its-CISCO.2.0.3.0.tcl
10       42978 Feb 18 2012 07:53:54 en_welcome.au
11       17167 Feb 18 2012 07:54:12 en_reenter_dest.au
12       14024 Feb 18 2012 07:54:28 en_invalid_extn.au
13       19512 Feb 18 2012 07:54:42 en_enter_dest.au
14       14352 Feb 18 2012 07:54:58 en_disconnect.au
15       26376 Feb 18 2012 07:55:10 en_dest_unreachable.au
16       42484 Feb 18 2012 07:55:24 en_dest_busy.au
191111168 bytes available (69042176 bytes used)
voice-port 0/0/1
supervisory disconnect dualtone mid-call
echo-cancel coverage 32
cptone SA
timeouts initial 0
timeouts interdigit 5
timeouts call-disconnect 1
timeouts ringing 5
timeouts wait-release 1
connection plar opx 2100
caller-id enable
caller-id alerting dsp-pre-allocate
Afandi-KBR-VGW#sh run |  s application|voice class|dial-peer voice 2100
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
codec preference 3 g711alaw
voice class h323 1
  h225 timeout tcp establish 3
application
service aa flash://its-CISCO.2.0.3.0.tcl
  param operator 2100
  paramspace english language en
  paramspace english index 0
  paramspace english location flash://
  paramspace english prefix en
  param aa-pilot 2100
global
  service alternate Default
associate application SCCP
dial-peer voice 2100 voip
description * SRST Auto-Attendant 2100 *
preference 1
service aa
destination-pattern 2100
session target ipv4:172.40.60.11
incoming called-number 2100
voice-class codec 1
dtmf-relay h245-alphanumeric
Your help will be highly appreciated.
Thanks & Regards,
Mudasir Abbas
Please reply
