SRST call-manager-fallback on SIP trunk for ISR 4K failing
lerner cisco
Hi ,
 SRST call-manager-fallback on SIP trunk for ISR 4K failing , when call manager made non availability , cisco phones not registering to gateway router.
am i missing something ?  please . below is the Gateway router configuration.
isdn switch-type primary-ni
trunk group PSTN-CIRCUITS
hunt-scheme longest-idle
voice call send-alert
voice rtp send-recv
voice service pots
voice service voip
no ip address trusted authenticate
allow-connections sip to sip
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface Loopback1
bind media source-interface Loopback1
rel1xx disable
min-se 900 session-expires 900
header-passing
error-passthru
midcall-signaling passthru
sip-profiles 1
voice class codec 2
codec preference 1 g711ulaw
codec preference 2 g729r8 bytes 30
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8 bytes 30
voice class sip-profiles 1
request REINVITE sdp-header Attribute modify "a=T38FaxFillBitRemoval:0" "a=Tool: GW"
request INVITE sdp-header Audio-Attribute add "a=ptime:30"
request REINVITE sdp-header Audio-Attribute add "a=ptime:30"
response ANY sdp-header Audio-Attribute modify "a=ptime:20" "a=ptime:30"
response ANY sdp-header Audio-Attribute add "a=ptime:30"
voice translation-rule 1
rule 1 /^36../ /64858336../
rule 2 /^44../ /54854244../
controller T1 0/2/0
framing esf
linecode b8zs
cablelength long 0db
pri-group timeslots 1-24
interface Serial0/2/0:23
description ** DIDs on PRI **
encapsulation hdlc
isdn incoming-voice voice
isdn send-alerting
trunk-group PSTN-CIRCUITS
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.10.10.10 port 2000 strict-match
max-ephones 60
max-dn 100 dual-line
system message primary TELEPHONY BACKUP MODE
transfer-pattern .T
call-forward pattern .T
dial-peer voice 1101 voip
description *Incoming 7 digits calls via PSTN directed to Sub1 **
destination-pattern .T
translation outgoing 1
rtp payload-type nse 99
rtp payload-type nte 100
session protocol sipv2
session target ipv4:20.10.10.10
voice-class codec 2
no voice-class sip g729 annexb-all
dtmf-relay rtp-nte
fax-relay sg3-to-g3
fax rate 14400 bytes 48
dial-peer voice 1102 voip
description *Incoming 7 digits calls via PSTN directed to Sub2 **
preference 2
session target ipv4:20.10.10.11
voice-class codec 2
dtmf-relay rtp-nte
fax-relay sg3-to-g3
dial-peer voice 1400 pots
trunkgroup PSTN-CIRCUITS
description ** Incoming DID calls via local PSTN service **
translation-profile incoming INCOMING
incoming called-number .
direct-inward-dial
dial-peer voice 1800 voip
preference 1
destination-pattern 0T
translate-outgoing calling 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1500 voip
description **Incoming calls via CUCM**
voice-class codec 2
dtmf-relay rtp-nte
fax-relay sg3-to-g3
max-ephones 60
transfer-pattern .T
interface Loopback1
description * Used for IPT signaling and SRST registration *
ip address 10.10.10.10 255.255.255.255
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.10.10.10
lerner cisco
please , Also want to understand , steps  of procedure the cisco IP phone does when call-manager connection lost and router become call manager fall back .
Are your phones SIP or SCCP?
Did you read the whole SRST configuration guide?
java
if this helps, please rate
the phones use both SIP and SCCP
There's no SIP SRST configuration, so I recommend you fully review the SRST configuration guide as your first step.
java
