SRST HELP - what am i doing wrong..?
james.hughes
Hi All - i'm doing my first deployment of CUCMBE 6.1 with CUPS. Everything running well... except SRST.
The handsets say:
1) x.x.x.x - callmanager 1 ACTIVE
2) x.x.x.x - callmanager 2 SRST
That all looks good.
My router looks like:
call-manager-fallback
secondary-dialtone 0
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.37.254.14 port 2000
max-ephones 96
keepalive 10
The source address here is the interface on the ISR router itself. Is that correct?
When i power down the CUCM the phones go blank and not into 'fall back mode'.
All help apperciated!
Thanks - James.
22 Replies 22
Can you please repost your config.. I am going to lab this, give me about 20 minutes, I have this gear at my house..
If you think any of this stuff helps, we at netpro suggest rating it!
Chad
Thanks mate - you'll be getting a 5 star rating!
GMOSYDISR01#sh run
Building configuration...
Current configuration : 2651 bytes
! Last configuration change at 15:37:02 SYD Wed Jun 25 2008
version 12.4
hostname xxx
boot-start-marker
boot-end-marker
card type e1 0 0
enable secret xxx
enable password xxx
no aaa new-model
resource policy
clock timezone SYD 10
network-clock-participate wic 0
ip cef
no ip domain lookup
stcapp ccm-group 1
isdn switch-type primary-net5
voice-card 0
no dspfarm
application
global
service alternate Default
username gmotech password 0 l0seme365
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
controller E1 0/0/1
interface GigabitEthernet0/0
ip address 10.37.254.14 255.255.255.0
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn protocol-emulate network
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip route 0.0.0.0 0.0.0.0 10.37.254.1
ip http server
no ip http secure-server
control-plane
voice-port 0/0/0:15
cptone AU
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
ccm-manager fallback-mgcp
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.37.254.10
ccm-manager config
ccm-manager download-tones
mgcp
mgcp call-agent 10.37.254.10 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 1 pots
destination-pattern 0....
dial-peer voice 10 pots
service mgcpapp
max-ephones 96
max-dn 96
dialplan-pattern 1 827499... extension-length 3
transfer-pattern .T
keepalive 10
call-forward pattern .T
line con 0
line aux 0
line vty 0 4
password xxx
login local
scheduler allocate 20000 1000
ntp clock-period 17180107
ntp server 10.42.10.11
end
GMOSYDISR01#
put in that dial peer for long distance, you may need to have it to ungrey the buttons :p may need a valid dial peer
Turns out my brand new ISR router was running the wrong version of IOS. Changed it and all is well. Thanks for all your help.
- James.
no probs, glad it is working... btw from what version was the error to what version fixed it!
This is what i had: c2800nm-advipservicesk9-mz.124-9.T7.bin
This is what i needed: c2800nm-advipservicesk9-mz.124-15.T5.bin
Thanks - JH
My standard IOS, and CVP Base IOS (irrelevent but for a reason I believe) is 12.4(15)T4 and I believe this is the minimum IOS anyone should be running right now!!!
Chad
How do you test SRST? Do you use ACL or static route? Can you show commands that are used for falling router in the SRST mode?
