SRST Hunt-Group Limit
refram
Level 3
Level 3
We have some new 8300 routers that we're using as voice gateways.  When configuring SRST, does anyone know how many phone numbers can be put into a parallel voice hunt-group?  I'm seeing it's 32 for CME, but I don't know if that is going to be the same for a router configured for plain-old SRST.
As SRST share much of its functionality and features from CME it would be very likely that the limit for this is the same. If you want to know for sure I would recommend you to configure it to see where it limits out. If you do please remember to update your post so that others in the community can benefit from this, both now and later if someone searches for the same information.
Response Signature
I appreciate the reply, Roger.
In the past I found that I could configure almost as many as I wanted, but only 7 phones would ring.  That, however, was probably 10 years ago, and I was wondering if anything had changed.  I would have thought there would be some documentation.  Oh well.  The logistics of trying to check whether up to 33 phones will ring in an office will be a bit tough based on our typical layout, but I'll see what I can do.
