SRST IP Phone registration issue
fuhrersk8
Level 3
Level 3
                   Hello guys!
Currently I'm configuring SRST on a Cisco 2921 in conjunction with a CUCM8.6 (BE6000). When testing SRST, the phones show "MODE SRST", some pick up dial tone, some not, and on phones with dialtone phone calls did not progress. On the Cisco 2921 the debug ccapi all did not show nothing when attempting calls during the SRST test. It appears to me like phones were unable to register with the Voice Gateway (Cisco 2921). Below is the partial SRST config of Voice Gateway. My questions are the following:
1. Does it is neccesary to configure manually the ephones and directory numbers in the Cisco 2921 or phones will be allocated by the router automatically?
2. How to determine the SRST versipon currently running on Cisco 2921? Phones are 7940, 7960 and 7912.
3. On dialpeers (both voip and pots) it is necesary to enable the service mgcpapp in order to permit SRST calls to flow through the dialpeer?
4. Please reviw the SRST config below and if I'm missing something let me know!
Thanks in advanced guys, appreciate your help.
Partial SRST configuration:
ccm-manager fallback-mgcp
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.200.54.3
ccm-manager config
mgcp
mgcp call-agent 10.200.54.3 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp ip qos dscp af31 media
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
no mgcp explicit hookstate
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0.54
mgcp bind media source-interface GigabitEthernet0/0.54
mgcp profile default
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.200.54.1 port 2000
max-ephones 25
max-dn 25
system message primary Operating in mode SRST
keepalive 10
default-destination 4123
moh music-on-hold.au
multicast moh 239.1.1.1 port 16384 route 10.200.54.3 10.32.84.54
31 Replies 31
Hello guys!
     When placing outbound calls, the digit 9 is not being stripped from the dial string, hence the call gets disconnected. See debug output below:
Calling Number=7875239999(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=97872350808(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=7875239999
   Account Number=, Final Destination Flag=FALSE,
   Guid=82143122-8FEA-11E2-8CDF-FB7E7963E215, Outgoing Dial-peer=20
059435: Mar 19 16:40:16.849 UTC: //8707/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=7875239999
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=97872350808
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Te dialpeer matched is:
dial-peer voice 20 pots
description Outbound Calls in MHQ
translation-profile outgoing External_Phone_Number_Mask
destination-pattern 9..........
port 0/0/0
I also tried with 9T, but same result. Any ideas on how to remove the digit 9 from dest=97872350808?
Thanks in advanced guys!
Thanks for all your help! SRST is working as intended. Outbound calls were failing due to invalid country codes configured on the voice-port. I removed those from the port and is working now. Thanks again!
