SRST Question
carl_townshend
Hi All
If I have an SRST gateway with a PRI line, under normal circumstances am I right in saying that the phones will be registered the to the CUCM, but will use the local PRI on the SRST gateway for outgoing PSTN calls? I gather this is done by local route groups?
cheers
Jinto Alakkal
Hi Carl,
Yes you are right you can route the calls like this using Standard/Enhanced (Named) local route groups, which you can assign from the device pool, this way you will eliminate the need of multiple route patterns for multiple sites, the route list will be pointing to the Standard local route group to route the calls through the local gateway.
 Hope this helps
Jinto.
Jinto Alakkal
Hi Carl,
 Hope this helps
Jinto.
