Cisco Unified Attendant Console Standard - Download
adnanhassan1
Hi Guys,
Any have any idea how can I download CUAC (Standard) software?
Thanks in advance
Adnan
You would find all the guides in the link below
http://www.cisco.com/c/en/us/support/unified-communications/unified-attendant-console-advanced/model.html
(Rate if it helps)
JB
15 Replies 15
Siva chinap
Level 5
Level 5
Adna,
Check it below, you CSCO id have acess to download the software.
http://www.cisco.com/c/en/us/support/unified-communications/unified-attendant-console-advanced/model.html#~tab-downloads
Thanks Jitender and Siva for prompt reply.
Wondering if you have any installation guide for CUAC-Standard?
(Rate if it helps)
JB
Recently only i deployed it .. You need to have windows server 2012.SQL=2012 and Demo licenses .
Hi Siva,
Where do you get the CUACS_Setup.exe? And do you need a server for it?
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cucmac/cuacs/10_5_1/install_admin_guide/CUACS1051GUIDE.pdf
How Yee
The link is right below How Yee.
And, no, you do not need a Server for Attendant Console Standard. You just install it on the workstation.
Georgios
Please rate if you find this helpful.
Jitender Bhandari
Hi Adnan,
You can get the software from the link below.
http://cisco-ac.arcsolutions.com/UserWebSite/cisco/ciscoDefault.aspx
(Rate if it helps)
JB
very helpful. It is very hard to find the link to download the standard version.
That looks like a phishing site. Is there an official download available for CUAC Standard?
Yes, http://www.cisco.com/go/ac
java
if this helps, please rate
Thanks Jaime,
I don't want to go down a rabbit hole here, but the cisco.com link you provided redirects to the same http://cisco-ac.arcsolutions.com site.  Can I ask what the relationship there is?  Is that a partner site?  Did they develop AC?  Or is this more of a ciscounitytools.com situation?
Yes, ARC is behind CUACA and CUACS.
java
I have tried to get registered but no response email received.
I have the same issue, our Barracuda blocked all emails:  no PTR Record found.
