SRST with 7841
SS_MO7722
Dear All
Kindly i have an issue with enable srst it is not work , we try to enable SRST in router 2901 and router license is
License Type: EvalRightToUse
License State: Active, In Use
Evaluation total period: 8 weeks 4 days
Evaluation period left: 8 weeks 1 day
and our CUCM V10.5 , and  IP phones type 7841 and kindly find below running configuration:-
voice-card 0
voice register global
mode srst
system message SRST
max-dn 35
max-pool 35
application
global
service alternate default
license udi pid CISCO2901/K9 sn FGL192020HM
license accept end user agreement
hw-module pvdm 0/0
redundancy
voice-port 0/0/0
impedance complex2
description Line 1
caller-id enable
voice-port 0/0/1
impedance complex2
description line 2
caller-id enable
voice-port 0/0/2
impedance complex2
description line 3
caller-id enable
voice-port 0/0/3
impedance complex2
description line 4
caller-id enable
mgcp
mgcp call-agent 10.0.2.254 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode cisco
mgcp bind control source-interface GigabitEthernet0/0.2
mgcp bind media source-interface GigabitEthernet0/0.2
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
ccm-manager music-on-hold
ccm-manager fallback-mgcp
ccm-manager mgcp
ccm-manager config server 10.0.2.254
ccm-manager config
dial-peer voice 1 pots
destination-pattern 9T
port 0/0/0
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.200.200.1 port 2000
max-ephones 35
max-dn 35
system message primary SRST
keepalive 20
time-zone 25
date-format dd-mm-yy
*** and we configure SRST reference in CUCM and Configure SRST in Device pool
5 Replies 5
Rajkumar Yadav
Level 4
Level 4
I think you missing many commands.
voice-card 0
 dspfarm
 dsp services dspfarm
voice service voip
allow-connections sip to sip
sip
bind control source-interface xx
  bind media source-interface xx
  registrar server expires max 3600 min 120
 mode srst
 max-dn 200
 max-pool 80
voice register pool  1
 id network x.x.x.x mask 255.255.255.0 // this is IP phone voice subnet
 dtmf-relay rtp-nte sip-notify
 codec g711ulaw
telephony-service
 sdspfarm units 10
 sdspfarm tag 1 CONF
 sdspfarm tag 2 XCODE
 sdspfarm tag 3 MTP_G711
 sdspfarm tag 4 MTP_G729
 conference hardware
 srst mode auto-provision none
 srst ephone template 1
 srst ephone description "SCCP SRST Service" : Aug 15 2015 14:53:56
 srst dn template 1
 srst dn line-mode octo
 max-ephones 80
 max-dn 200
 ip source-address x.x.x.x port 2000
 timeouts interdigit 4
 time-zone 26
 time-format 24
 transfer-pattern 9T
Please try above commands and let me know.
Also make sure you have SRST configured for both SIP and SCCP in CUCM.
Also share the license details command output.
you should have uck9 permanent license.
Raaj
Dear Rajkumar Yadav
thank you for your reply
are you sure about cancel MGCP fallback and configure telephony service ?
and i sure have uck9 permanent license.
I would prefer to configure the Cme as Srst configuration.
could you please confirm did the 7841 phones registered in Srst mode ?
Raaj
You are using SIP SRST. So you need to fill the SIP SRST IP Address in SRST Reference. Is this there?
If the SRST reference is right on CUCM, we should see an attempt from phone to register to router, which can be verified doing "debug ccsip message" [Look for REGISTER messages from that specific phone].
~Avinash
Dear
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
mode srst
system message SRST Service Active
max-dn 35
max-pool 35
id network 10.200.200.0 mask 255.255.255.0
voice-class codec 1
application
global
hw-module pvdm 0/0
encapsulation dot1Q 2
ip address 10.200.200.1 255.255.255.0
mgcp
mgcp call-agent 10.5.5.200 service-type mgcp version 0.1
ccm-manager mgcp
ccm-manager config server 10.5.5.200
ccm-manager config
port 0/0/0
sip-ua
gatekeeper
shutdown
timeouts interdigit 2
ip source-address 10.2.2.1 port 2000
max-ephones 35
max-dn 35
system message primary SRST Mode
keepalive 20
time-zone 25
*** this is current configuration there is any missing configuration
