SRTP config example for voip trunks
kursatcoban
William Bell
MGCP doesn't fit your requirements but you could use h323. You would need to configure ipSec to support the call signaling (if you want) and SRTP to support the media. Here is a Cisco write up on Media and Signaling encryption for IOS gateways:
https://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/htsecure.html
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
6 Replies 6
William Bell
HTH.
Bill
Marwan ALshawi
if you use IPsec and you have any concern about QOS make sure to enable pre classify feature on the ipsec tunnel for QOS to make sure you keep the traffic marking and to avoid any qos issues
William Bell
I think that the original poster is looking for information on SRTP not SRST.
thanks for that
Hi All ,
I found it , here is the sample config
voice-card 1
codec complexity high
local-bypass
conf t
voice service  voip
sip
url sip
srtp negotiate cisco
exit
exit
conf t
dial-peer voice xxx voip
srtp
srtp system
security mode encrypted
exit
regards,
Kursat
can i ask some question about the SRTP protocol?
1. how can i configure the SRTP protocol for bandwidth guarantee in QOS rules;
2. what is the SRTP port used?
3. what is the ios for the SRTP command in dial-peer?
