SRTP, CUBE & Multi-SAN CUCM Certificate
Gordon Ross
Level 9
Level 9
I've read two Cisco documents on setting up a secure SIP trunk between CUBE and CUCM. Both documents talk about importing every node's Callmanager certificate into CUBE.
But what if you've got a multi-SAN certificate for CallManager? (I.e. One certificate for all nodes in the cluster) Do I have to import the same certificate for each node in the cluster, or is there another way to do it?
Please rate all helpful posts.
Jaime Valencia
This follows the same basic rules of certificates/encryption you would follow in CUCM, there's nothing special in that regards.
Most likely the doc you looked at did that because they were using self-signed certs, and then each server acts as a standalone CA.
In my lab as I use the same CA for everything, I generated the CSR request on the ISR, had it signed, then uploaded the same root CA I use in CUCM and the signed certificate and that's it. I'm able to have TLS/SRTP between them
java
if this helps, please rate
That's good to know. I wondered if something clever was going on and each server's SSL certificate had to be validated against it's name/IP address. So it looks more like that CUBE is just checking that the certificate is recognised and doesn't care where it comes from.
BTW - If my CUCM certificate is signed by a CA (Commercial or othewise) do I need to upload the full certificate chain, or just the CUCM endpoint certificate?
