05-24-2011 11:24 PM - edited 03-16-2019 05:08 AM
I need to configure cisco 2801 router as an SS7 gateway from the PSTN side and a SIP dial peer from the VoIP side. The router include a E1 interface, Is this configuration is possible? is there a documents shows such configuration?
With best regards
Essa Anas
05-25-2011 12:00 AM
The router cannot interpret SS7 by itself. It does that with another device, the PGW, aka softswitch.. It is all part of a complex architecture for which you should check with your cisco senior systems engineer, or a very expereinced consultant.
05-27-2011 05:35 AM
Hi Essa
You need Cisco hardwares like PGW2200 and AS5400 Media Gateways to do the SS7 interconnection with your provider. Your 2800 Router will not support ss7 functionality.
Refer this sheet for ss7 solutions.
Revert incase of any further requirements. Thanks.
Pl rate if info is useful.
