06-18-2009 09:11 AM - edited 03-15-2019 06:36 PM
I am in the early stages of troubleshooting users reporting static on the phones when they are on a call. Based on others with the same issues what would be the best place to look for an issue that may cause this. In other words when this happens what is the main reason or reasons for static?
Mike
06-18-2009 10:16 AM
Which type of line do you have to pstn ?
06-18-2009 11:13 AM
When you say which type of line what do you mean?
Mike
06-18-2009 11:17 AM
Analog lines, or T1 lines ?
06-18-2009 11:28 AM
The users are connected to a Catalyst 4506-E switch which then goes into a 2821 router and comes back to a central location via T-1 MPLS. This is the way most all our offices are setup, we are Hub and Spoke. Not all users are having this issue. They are all Cisco IP Phones (7965).
Mike
06-18-2009 11:44 AM
Somewhere, there is one or more telephone lines going to telco, you need to find out that.
06-18-2009 11:53 AM
Sorry me being dense..... T-1 not analog
It has been one of those days.
Mike
06-18-2009 11:56 AM
Post output of "show controllers T1" taken on the router that terminates said T1.
06-18-2009 11:59 AM
2821#show controllers t1
T1 0/2/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20071129, FPGA: 20, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (368 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
58 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
58 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
13708 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
13708 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
06-18-2009 12:04 PM
conf t
network-clock-participate wic 2
network-clock-select 1 t1 0/2/0
Let us know if that fixes the issue, else more questions coming.
06-18-2009 12:10 PM
is already configured...the other is not...
06-18-2009 12:12 PM
Configure for both and the all important -select command.
06-18-2009 12:20 PM
Thank you...
Since I will be asked and I don't configure that everyday. How did you arrive at that and can it have any adverse affects?
Mike
06-18-2009 12:37 PM
No adverse effects, we're not here to make you suffer. That will eliminate the slip errors that you can see in show controllers. Who initially configured in the router was not a professional.
06-18-2009 12:42 PM
Thankfully I did not configure...Still learning the VoIP configs...
I will put this in place I just need to run it by the powers in place.. :-)
Thanks for your help.
Mike
