12-08-2010 03:46 PM - edited 03-16-2019 02:20 AM
I was hoping someone can help me sort out the status error messages I'm receiving on two 7911 phones I have configured in my LAB. The errors are listed below:
1) Error Updating Locale
2) SEP%MAC%.cnf.xml
2) No CTL Installed
3) File Not Found: CTLFile.tlv
I really have a bare configuration on the CME.
Here is a snippet from telephony service
telephony-service
max-ephones 10
max-dn 10
ip source-address 192.168.5.254 port 2000
system message RTP CME LAB
load 7911 SCCP11.8-5-4S
time-zone 12
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Dec 08 2010 18:29:28
Also, something odd but when I run debug tftp events and reload a phone, I do not get any output. I appreciate any help.
12-08-2010 10:12 PM
Hello Paul,
is the option 150 set to the ip address from the tftp-server?
Could you set an alternate tft-server on the phone:
Unlock the settings with **#
Settings => Network Configuration => IPv4 => Alternate TFTP (YES) and TFTP Server 1 (IP from CME)?
Kind regards,
Marcel Ammann
12-09-2010 09:18 AM
The CME is handing out DHCP to the Phones and Option 150 is set.
12-09-2010 09:22 AM
These are perfectly normal and expected messages, and there is nothing to worry about.
Most likely, you are not getting output becuase because you did not typed "terminal monitor".
12-09-2010 11:29 AM
Well, the reason I thought it may be an issue is that when I select the Directories button I do not see Local Directory and I see a message on the display Host not Found.
12-09-2010 11:59 AM
The User-Locale issues are because the router is looking for these:
tftp-server flash:g3-tones.xml alias United_States/g3-tones.xml
tftp-server flash:tc-sccp.jar alias English_United_States/tc-sccp.jar
I've added them in and it clears up the issue.
