Strange headset problem on Cisco 7945
Vadim Semenov
Hi, All,
strange problem with 7945 occured after rebooting CUCM - "headset" button lit all the time (of course headset is connected) so if call is coming on the IP Phone - you should press "Headset" button twice(!). How it's possible to set the IP Phone or IP Phone profile in CUCM 9.1 that "Headset" button is off all the time in order to if headset is already plug in and i want to answer call - i press headset button one time ( i can press button near the display or soft button "Answer", but it doesn't usable/confortable).
In DN setting auto answer is OFF.
Manish Gogna
Hi Vadim,
What is the firmware version of the IP phone? You may want to check the following bug
https://tools.cisco.com/bugsearch/bug/%20CSCul48799
79xx phone should support default audio path
CSCul48799
Symptom:This enhancement brings the 79XX phones audio path selection in line with all newer phone models.
Manish
- Do rate helpful posts -
Manish Gogna
Hi Vadim,
CSCul48799
Manish
 Firmware is SIP45.9-4-2SR1-1S
