we have setup CTRS the CTRS sit in a DC and we have two CTSs one is 3010 and the other one CTS 500 in one building and they use same Vlan trunked for two L2 switches
TP meetings using those CTSs perfect
playback of Recorded media using the CTS 3010 very good
however when we use the CTS 500 it shows pixlization and two bars of the bandwidth bars on the screen ( while this issue not happening woth normal TP meeting) and again this end point uses same path that the 3010 uses and as i mentioned the CTS 3010 has no issue
even if Record using the 500 and play it back same issue
not sure how to troubleshoot this one, i am sure it is not network bandwidth issue, why it happens with this end point!! is there is possibility a CTS iisue and how to prove it
thank you
