Sub - Low Available Virtual Memory Alert
Jagsuvce G
Am seeing Low Available Virtual Memory Alert in one of the Subscriber. CUCM Version is 8.6.
Pls suggest.
vemanyam
Check ram, minimum 4GB.
Try restarting tomcat if don't solve the issue....
Rebooting server is a quick solution.
Try to restart Tomcat Service and, if not help restart also RISDC service.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
vemanyam
After rebooting the server the issue got resolved.
