02-23-2011 02:34 AM - edited 03-16-2019 03:36 AM
Hello
I have a strange problem with my subscrober cucm 7.0. When I register IP-Phone on publisher every thing works fine but when I register same IP-Phone on my subscriber callmanager, It couldn't dial route patterns. CSS configured correctly. I reset subscriber but problem doesn't fixed. is it a database problem or anything esle?
02-23-2011 04:10 AM
Check that the publisher - subscriber replication status is ok.
Michael.
02-23-2011 06:29 AM
It's hard to tell what's wrong with just that info, couple of things to check would be the DB replication as already mentioned and perform a cluster reboot to clear any SDL layer issues you might have that could cause this.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
