05-28-2013 10:07 AM - edited 03-16-2019 05:33 PM
This is a follow on from the sip ringing out issue.
https://supportforums.cisco.com/message/3949262#3949262
Topology below:
CUCM -- SIP Trunk -- CUBE -- SIP Trunk -- ITSP
Basically when a call is put on hold/transferred i see the invite being received from the CUCM with audio inactive.
CUBE then send this on to the ITSP and receives an ok from the ITSP.
CUBE the sends an ACK to the ITSP but then after this sends a bye message to tear down the call.
Ive attached the debug from the point of hold.
Below is how voice service voip is currently configured:
voice service voip
ip address trusted list
ipv4 x.x.x.x
ipv4 x.x.x.x
ipv4 x.x.x.x
ipv4 x.x.x.x
mode border-element license capacity 50
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
no supplementary-service sip handle-replaces
redirect ip2ip
signaling forward rawmsg
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
emptycapability
h225 signal overlap
h225 connect-passthru
call start interwork
h245 passthru tcsnonstd-passthru
sip
no update-callerid
early-offer forced
midcall-signaling passthru
Kev
Solved! Go to Solution.
05-28-2013 10:35 AM
I have replied to your previous post
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
05-28-2013 10:35 AM
