SX10 Auto Reboot or Max Call Duration
ahagerma1
I'm trying to find out how to set an SX10 to automatically reboot daily, or set a maximum call duration timer. Does anyone know if this is possible?
Thank you!
Wayne DeNardi
There is no setting on the device itself to be able to do this.
You would need to use some external device (eg a PC) and schedule that to run a script to connect to the endpoint and reboot it.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Patrick Sparkman
There is no option to set a max call duration on any Cisco endpoints, unlike there was on the older TANDBERG MXP endpoints.
If you use TMS, you can create a configuration template and set it to reboot endpoints on a daily or weekly schedule.
dsobrinho
Level 9
Level 9
share the version of firmware and give more detail about reboot?
Can be a bug!!!.
Best regards,
Daniel
Daniel Sobrinho
