SX20 options
nadine
What software options are available?
9 Replies 9
admin11111
Level 4
Level 4
Can a software client be installed on a laptop to enable video conferencing between a remote employee with one of the main sites?
tiorourk
MultiSite, Dual display, and premium resolution are all options for the SX20 Quick Set.
What resolution is supported as standard (without the Premium Resolution license)?
720 p and below see the data sheets of details
PR adds 1080 p 30 and 720 p60 possibly 1080 p 60 as and when camera end up supporting it
Srini
By they way, the limitation of 720p30 without the Premium Resolution option applies *only to transmitted and received video*.
Local video from a PC or SelfView will display at the native resolution up to 1080p60 or 1920x1200.  We recommend that a 1080p or 1920x1200 monitor be used to avoid video scaling at the output of the SX20.
if i connect to a b2b webex on the SX20 would a call of 1080p actually connect and use 1080p to webex  default 720p (webex default) if so the premium resolution is useless over webex ?
admin11111
Level 4
Level 4
The second question was never answered.  Is there a software client that will connect a laptop/desktop with a web cam to a site that has an SX20?
Yes, any standards-based SIP software client can connect to SX20 or any otther Cisco TelePresence endpoints.  Cisco offers Cisco Jabber Video for TelePresence as a soft client for video.
admin11111
Level 4
Level 4
PR,DD,MS
