Syslog message severity
tprochazka
Hi Guys,
please dont you know, if there is a chance to change severity of remote syslog messages
within CUCM 7.1(3) ? I would like to log severity lever "errorr" but besides important messages
it logs many useless ones (by these ones I would like to reduce severity level).
Thanks in advance.
Tomas
when you enable remote syslog alarm
you can define the alarm level from emergency to detailed
So you can choose any level lower than error
I know, as I write, I defined "error" level, but problem is that some of "errorr" level messages I would like to move to lower level in order to not received them on syslog server...
