03-20-2012 02:38 PM - edited 03-16-2019 10:13 AM
Does anyone know if T.38 v3 fax relay is supported on Cisco ISRG2 gateways running MGCP? The documentation that I've found talks about it being supported for SIP and H323 but not for MGCP...but these documents are not necessarily current. I am curious if support is available now? We do have SuperG3 running fine using modem passthrough, but I know T.38 is the preferred method for FoIP. Thanks.
Bill
Solved! Go to Solution.
03-20-2012 03:46 PM
No, MGCP does not offer protocol based T.38 V3, currently only H323 and SIP offer it as of IOS 15.1.1T.
HTH,
Chris
03-20-2012 03:46 PM
HTH,
Chris
03-20-2012 05:28 PM
Thanks, Chris. We'll stick with modem passthrough I suppose until Cisco gets around to implementing it.
