T1 CAS Trunk Line/Path Code Violations?
I received a compliant from an attendant of dropped calls when transferring  at a remote site.
What I though was a PRI line at the site turned out to be a CAS trunk. I've never dealt with these before.
I noticed a lot of line/path code violations. Could this be the cause of my trouble?
Does anyone see anything obvious in the config or have any suggestions to share?
Phill
Config is as follows:
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
controller T1 0/0/0
 linecode ami
 cablelength long 0db
 ds0-group 0 timeslots 1-24 type e&m-wink-start dtmf dnis
voice-port 0/0/0:0
 description Fred_Flintstone_Mutual_Telco_Ckt#
Show controllers output:
SlateQuaryGtwy1#sh controller t1
T1 0/0/0 is up.
  Applique type is Channelized T1
  Cablelength is long 0db
  No alarms detected.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Version info Firmware: 20100222, FPGA: 13, spm_count = 0
  Framing is ESF, Line Code is AMI, Clock Source is Line.
  CRC Threshold is 320. Reported from firmware  is 320.
  Data in current interval (570 seconds elapsed):
     5670 Line Code Violations, 3276 Path Code Violations
     1 Slip Secs, 0 Fr Loss Secs, 163 Line Err Secs, 8 Degraded Mins
     163 Errored Secs, 145 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 3 15 minute intervals):
     11358 Line Code Violations, 5578 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 829 Line Err Secs, 44 Degraded Mins,
     831 Errored Secs, 687 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
SlateQuaryGtwy1#sh voice port 0/0/0:0
recEive and transMit Slot is 0, Subslot is 0, Sub-unit is 0, Port is 0
 Type of VoicePort is E&M
 Operation State is DORMANT
 Administrative State is UP
 No Interface Down Failure
 Description is Fred_Flintstone_Mutual_Telco_Ckt#
 Noise Regeneration is enabled
 Non Linear Processing is enabled
 Non Linear Mute is disabled
 Non Linear Threshold is -21 dB
 Music On Hold Threshold is Set to -38 dBm
 In Gain is Set to 0 dB
 Out Attenuation is Set to 0 dB
 Echo Cancellation is enabled
 Echo Cancellation NLP mute is disabled
 Echo Cancellation NLP threshold is -21 dB
 Echo Cancel Coverage is set to 128 ms
 Echo Cancel worst case ERL is set to 6 dB
 Playout-delay Mode is set to adaptive
 Playout-delay Nominal is set to 60 ms
 Playout-delay Maximum is set to 1000 ms
 Playout-delay Minimum mode is set to default, value 40 ms
 Playout-delay Fax is set to 300 ms
 Connection Mode is normal
 Connection Number is not set
 Initial Time Out is set to 15 s
 Interdigit Time Out is set to 10 s
 Call Disconnect Time Out is set to 60 s
 Ringing Time Out is set to 180 s
 Wait Release Time Out is set to 30 s
 Companding Type is u-law
 Rx  A bit no conditioning set
 Rx  B bit no conditioning set
 Rx  C bit no conditioning set
 Rx  D bit no conditioning set
 Tx  A bit no conditioning set
 Tx  B bit no conditioning set
 Tx  C bit no conditioning set
 Tx  D bit no conditioning set
 Rx Seize ABCD bits = 1111 Default pattern
 Rx Idle ABCD bits = 0000 Default pattern
 Tx Seize ABCD bits = 1111 Default pattern
 Tx Idle ABCD bits = 0000 Default pattern
 Ignored Rx ABCD bits =  BCD
 Region Tone is set for US
 Analog Info Follows:
 Currently processing none
 Maintenance Mode Set to None (not in mtc mode)
 Number of signaling protocol errors are 11438
 Station name None, Station number None
 Translation profile (Incoming):
 Translation profile (Outgoing):
 lpcor (Incoming):
 lpcor (Outgoing):
 Voice card specific Info Follows:
 Operation Type is 2-wire
 E&M Type is 1
 Signal Type is wink-start
 Dial Out Type is dtmf
 In Seizure is inactive
 Out Seizure is inactive
 Digit Duration Timing is set to 100 ms
 InterDigit Duration Timing is set to 100 ms
 Pulse Rate Timing is set to 10 pulses/second
 InterDigit Pulse Duration Timing is set to 750 ms
 Clear Wait Duration Timing is set to 400 ms
 Wink Wait Duration Timing is set to 200 ms
 Wait Wink Duration Timing is set to 550 ms
 Wink Duration Timing is set to 200 ms
 Minimum received Wink Duration Timing is set to 140 ms
 Maximun received Wink Duration Timing is set to 290 ms
 Minimum seizure Timing is set to 50 ms
 Delay Start Timing is set to 300 ms
 Delay Duration Timing is set to 2000 ms
 Dial Pulse Min. Delay is set to 140 ms
 Percent Break of Pulse is 60 percent
 Auto Cut-through is disabled
 Dialout Delay is 70 ms
 Hookflash-in Timing is set to 480 ms
 Hookflash-out Timing is set to 400 ms
 DS0 channel specific status info:
                                      IN      OUT
PORT            CH  SIG-TYPE    OPER STATUS   STATUS    TIP     RING
0/0/0:0          01  e&m-wnk     dorm idle     idle
0/0/0:0          02  e&m-wnk     dorm idle     idle
0/0/0:0          03  e&m-wnk     up   seized   seized
0/0/0:0          04  e&m-wnk     dorm idle     idle
0/0/0:0          05  e&m-wnk     dorm idle     idle
0/0/0:0          06  e&m-wnk     dorm idle     idle
0/0/0:0          07  e&m-wnk     up   seized   seized
0/0/0:0          08  e&m-wnk     dorm idle     idle
0/0/0:0          09  e&m-wnk     dorm idle     idle
0/0/0:0          10  e&m-wnk     up   seized   seized
0/0/0:0          11  e&m-wnk     dorm idle     idle
0/0/0:0          12  e&m-wnk     dorm idle     idle
0/0/0:0          13  e&m-wnk     dorm idle     idle
0/0/0:0          14  e&m-wnk     dorm idle     idle
0/0/0:0          15  e&m-wnk     dorm idle     idle
0/0/0:0          16  e&m-wnk     up   seized   seized
0/0/0:0          17  e&m-wnk     dorm idle     idle
0/0/0:0          18  e&m-wnk     dorm idle     idle
0/0/0:0          19  e&m-wnk     dorm idle     idle
0/0/0:0          20  e&m-wnk     dorm idle     idle
0/0/0:0          21  e&m-wnk     dorm idle     idle
0/0/0:0          22  e&m-wnk     dorm idle     idle
0/0/0:0          23  e&m-wnk     dorm idle     idle
0/0/0:0          24  e&m-wnk     dorm idle     idle
George Thomas
Level 10
Level 10
Line code violations are usually a provider problem or a cabling problem. I would open a case with the provider and they should be able to do some tests on your circuit.
Please rate useful posts.
George Thomas
Level 10
Level 10
Turns out that it was improper line coding.
Telco was set to B8ZS...my side was set to AMI. Errors went away as soon as this was set correctly. Kind of questioned that from the beginning...AMI is unusual this day and age.
