T1 to FXS Configuration Question: Dial-peer's okay?
jsulliva
I have  an issue, I'm getting a fast-busy when I call from 555-6002 to 555-5028.  Where am I going wrong with this?
  • Calls work from 555-6002 to 555-5000
  • Calls work from 555-5028 to 555-6002
  • Calls Fail from 555-6002 to 555-5028
ephone-dn  1  dual-line
 number 5000 secondary 5555000
 name Sara Driscoll
dial-peer voice 1 pots
 destination-pattern 5555028
 port 0/3/1
dial-peer voice 3 pots
 incoming called-number 5555...
 direct-inward-dial
 port 0/2/0:23
dial-peer voice 2 pots
 destination-pattern 555[4,5,6]...
 port 0/2/0:23
 forward-digits all
FULL CONFIG
! Last configuration change at 15:12:39 UTC Tue Sep 30 2014
version 15.1
hostname RouterVOIP1
boot-start-marker
boot-end-marker
card type t1 0 2
no aaa new-model
memory-size iomem 5
network-clock-participate wic 2
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 10.15.0.1 10.15.0.10
ip dhcp pool Voice
 network 10.15.0.0 255.255.255.0
 default-router 10.15.0.1
 option 150 ip 10.15.0.1
no ipv6 cef
isdn switch-type primary-ni
voice-card 0
license udi pid CISCO2811 sn FTX1151A3PR
username class privilege 15 password 0 cisco
redundancy
controller T1 0/2/0
 cablelength long 0db
 pri-group timeslots 1-8,24
interface FastEthernet0/0
 no ip address
 duplex auto
 speed auto
interface FastEthernet0/0.1
 encapsulation dot1Q 1
 ip address 10.1.0.1 255.255.255.0
interface FastEthernet0/0.10
 encapsulation dot1Q 10 native
 ip address 10.10.0.1 255.255.255.0
interface FastEthernet0/0.15
 encapsulation dot1Q 15
 ip address 10.15.0.1 255.255.255.0
interface Service-Engine0/0
 no ip address
 shutdown
interface FastEthernet0/1
 ip address 172.20.0.1 255.255.255.0
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0
 no ip address
 shutdown
 no fair-queue
 clock rate 2000000
interface Serial0/0/1
 no ip address
 shutdown
 clock rate 2000000
interface Serial0/2/0:23
 no ip address
 encapsulation hdlc
 isdn incoming-voice voice
 no cdp enable
router eigrp 100
 network 10.0.0.0
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
tftp-server flash:CME_8.6/cmterm-7940-7960-sccp.8-1-2/P00308010200.bin alias P00308010200.bin
tftp-server flash:CME_8.6/cmterm-7940-7960-sccp.8-1-2/P00308010200.loads alias P00308010200.loads
tftp-server flash:CME_8.6/cmterm-7940-7960-sccp.8-1-2/P00308010200.sb2 alias P00308010200.sb2
tftp-server flash:CME_8.6/cmterm-7940-7960-sccp.8-1-2/P00308010200.sbn alias P00308010200.sbn
tftp-server flash:CME_8.6/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:CME_8.6/ringtones/RingList.xml alias RingList.xml
tftp-server flash:CME_8.6/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:CME_8.6/music-on-hold.au alias music-on-hold.au
tftp-server flash:CME_8.6/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:CME_8.6/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:CME_8.6/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:CME_8.6/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:CME_8.6/ringtones/AreYouThere.raw alias AreYouThere.raw
control-plane
voice-port 0/2/0:23
voice-port 0/1/0
 ring number 2
voice-port 0/1/1
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
mgcp profile default
 port 0/3/1
 direct-inward-dial
 port 0/2/0:23
 port 0/2/0:23
 forward-digits all
telephony-service
 max-ephones 10
 max-dn 40
 ip source-address 10.15.0.1 port 2000
 load 7960-7940 P00308010200
 keepalive 10
 max-conferences 8 gain -6
 transfer-system full-consult
 create cnf-files version-stamp Jan 01 2002 00:00:00
 name Sara Driscoll
ephone-dn  2  dual-line
 number 5001
 name Jenny Parker
ephone  1
 device-security-mode none
 mac-address 001F.6C7F.973B
 button  1:1
ephone  2
 mac-address 001F.6C80.FDE9
 button  1:2
line con 0
 logging synchronous
line aux 0
line 194
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
Hi.
Please activate a debug voice ccapi inout, test the failing call and post the output
Carlo
Please rate all helpful posts "The more you help the more you learn"
6 Replies 6
acampbell
Can you try mod in your existing DP 3 pots
EXISTS
 direct-inward-dial
 port 0/2/0:23
MODIFY
desc *** MATCH INCOMING CALLS ***
no incoming called-number 5555...
 incoming called-number 555....
 direct-inward-dial
 port 0/2/0:23
Alex
Regards, Alex. Please rate useful posts.
Thank you for the reply and trying to help me out, I really appreciate it.  I"m still racking my brain.
Based on the commands below it seems the dial-peers are okay.  I wonder if its the T-1, but that appears okay too.
lobal ISDN Switchtype = primary-ni
ISDN Serial0/2/0:23 interface
        dsl 0, interface ISDN Switchtype = primary-ni
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x800000FF
    Number of L2 Discards = 0, L2 Session ID = 3
    Total Allocated ISDN CCBs = 0
Hi.
Carlo
The dial peer in the config for 5555028 shows as :-
 port 0/3/1 <------------------------------------------------ VP 0/3/1 ???
But look at the "show dial peer voice summary" ouput
1 pots up up 5555028 0 up 0/3/0 <----------------------------- VP 0/3/0 ???
Can you recheck the config which port is correct ???
Alex
Hi Alex,
Thank for your the reply, I had a different FXS card that I swapped out with the output.  FXS 0/3/0 is the correct port, I'll reflect that change in the drawing.
Carlo, thank you for your reply.   That helped me out a great deal.   When debugging "debug voice ccapi inout"  it yielded no results which had me thinking...that isn't right.
Through further investigation I found that the PBX was to blame "Bad Adtan PBX!"
I'll raise the issue with Adtran.
