TBCT Problem
kursatcoban
Hi All ,
I’m trying to use a feature commonly known as 2 B channel Transfer (TBCT) or Release Link Trunk. Nortel/ Avaya  call this feature Anti-Tromboning .
Firstly let me explain what i am trying to do. As you can see from the attached topology ,  i will configure a AA in Unity Connection. The calls initiated from CS1000 hits the  Unity Connection and  the caller hears the prompt,  dials a CS1000 extension.  Right after the call is transferred to corresponding CS1000 extension the call is established.
The problem is every call requires 2 ports , and the ports are busy during the call duration. ( although Unity Connection ( 8.0.3 ) is configured as “ release to switch” , the ports are not released. )
The implementation is simple ;
interface Serial0/1/1:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5 (  tbct is supported only with net5 or ni )
isdn incoming-voice voice
isdn supp-service tbct
isdn bind-l3 ccm-manager
no cdp enableand
i enabled the  TRMB ( Anti-Tromboling ) on the Avaya/Nortel Cs1000 side. But i get attached error message  from the ISDN trace.
Any suggestions or any other methods that i can accomplish to do this .
Marcos Assakawa
Hi, CUCM supports path replacement that would allow you to accomplish with your goals, but it only works with QSIG.  Here is more information about the Path Replacement: http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/admin/8_5_1/ccmsys/a08procl.html#wp1156114  I hope this helps.  Marcos
Marcos Assakawa
Hi Marcos ,
Thanks for your help. It is correct.
For those who are facing similar problems , here is a useful link.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/532642nt.pdf
Kursat
