Tcl IVR digit collect issue
Humza Khan
Assalam-o-Alikum,
I am having an issue regarding TCL IVR digit collection. Calls are working fine but when we dial an extension suppose 6657, on 3rd digit call hits on 6666 automatically, i running same tcl script in HO site. After this issue on remote site some changes done by myself in script but all in vain. i m attaching both actual and current tcl script. This issue checked through debug digit collect command. Debug logs are attached as well.
HK
17 Replies 17
Hi Humza..
Can you please post your actual config?
Carlo
Please rate all helpful posts "The more you help the more you learn"
Dear Carlo,
Please find attached actual and tcl related config files.
HK
Hi.
In configuration you posted , you are missing the queuing part of application and other fundamental variable for a dial-by-extension .
What is the purpose of that application?
Please activate a debug voip application script, make a call to the application and post the output.
Carlo
Dear Carlo,
We are using tcl for basic ivr service. Logs file attached.
HK
Hi Humza.
On debug you sent, I don't see the behaviour  you reported.
Please collect following logs:
debug voip diapeer inout
Of what I understand, this application should play a prompt asking the caller to insert a sequence of digits for desired destination.
Am I correct?
Let me know
Carlo
Dear Carlo,
Yes, you are correct. Please see log file.
Now client office is close, so i will be with you tomorrow on same time.
Thanks for your support
HK
Hi.
Script is good and works correctly.
We have to look at dial plan.
From your debug, you are trying to reach extension 6655 and VG collects and routes the call correctly.
You have 3 diapeers for the same destination 6000,6001 and 2585 pointing to 10.101.100.1 (2 identical diapeers ) and to 10.101.100.2 (1 DP) I suppose they are 2 CUCM
Can you check on cucm if extension 6655 is working correctly and if there are some active forwarding rules on dn configuration page.
Please try to configure a diapeer as follows
dial-peer voice 6655 voip
destination-pattern 6655
session target ipv4:10.101.100.1
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
After that try to call your application and select 6655
Activate a debug voip ccapi inout and post the output
Carlo
Dear Carlo,
Actually i m dialing 6587 ext. number from my phone after greeting, but call hitting on 6655 extension. I am unable to understand how to tackle this thing.
HK
Dear Carlo,
Output log file attached, kindly review.
I am dialing 6587 extension but call going on 6655. That's the issue i m facing.
As you said i have created dial-peer for this extension as well, but issue remains same.
dial-peer voice 7055 voip
 destination-pattern 6587$
 voice-class codec 1
 no vad
HK
Hi Humza.
On your dial-peer 7050 please modify dtmf-relay in h245-alphanumeric only.
Try it and activate a debug voip application script and a debug voip ccapi inout
Carlo
Dear Carlo,
Please find attached file. Logs taken after changing Dial-peer.
DGK-Voice#
DGK-Voice#sh run | sec dial-peer voice 7050
dial-peer voice 7050 voip
 service ivr
 incoming called-number 900
 voice-class codec 1
 no vad
HK
Issue has been resolved by changing script.
Thanks for your help.
HK
Now in this tcl everything is working fine, but fxo call issue observed phone constantly ringing after a call hang. So i have taken pcm capture but having trouble in open pcm log file. File attached.
Calling Number:4235762403    OR    4235717568
Called Number Extension: 6630
HK
Hi Humza.
Glad that it's working now.
Did you modify the script or you used the One from Cisco?
Carlo
