Tcl IVR digit collect issue
Humza Khan
Assalam-o-Alikum,
I am having an issue regarding TCL IVR digit collection. Calls are working fine but when we dial an extension suppose 6657, on 3rd digit call hits on 6666 automatically, i running same tcl script in HO site. After this issue on remote site some changes done by myself in script but all in vain. i m attaching both actual and current tcl script. This issue checked through debug digit collect command. Debug logs are attached as well.
HK
17 Replies 17
Hi Carlo,
I have added inter digit timeout command in script and reloaded. Its start's working.
Kindly suggest for the pcm logs, which are attached in below post.
HK
Hi Humza.
That's strange.
I have both your modified script and the cisco original one... all is working great with E1,FXO and SIP trunk....
Also tested al 3 options on both CUCM and CUCME environment.
For pcm you should rise a tac to analyse that file.
In you capture audio only, you can use audacity to import and listen.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
Tac case solve the case, thanks for your entire help.
HK
