05-17-2013 07:43 AM - edited 03-16-2019 05:23 PM
Hi all,
Good Morning,
I have a Technical Question.
This this the scenario: I scheduled my CUCM to have a backup 3 times a week, maintaining a maximum of 3 copies on the backup server, that means that the most oldest back up version of my CUCM will always have one week. So, every back up is made of 2GB each, and I have a assigned quote of 7 GB on mi DRS system, 7GB will make impossible a fourth copy CUCM back up (even if I tune that on the DRS parameters).
What I want to know is, when my quote of 7GB has only a 1GB space LEFT, and the call manager is making the next back up, Does CUCM first erase the older copy and then replace the new one? or Does it first insert the new one and delete the oldest copy?.
I'm asking this because I want to get more space in the backup system, but my storage admin want to know exactly how many GB I will need.
I am using a CUCM ver 8.6, scheduling a Backuo 3 time a week and only maintaining 3 copies on the storage.
Solved! Go to Solution.
05-20-2013 05:43 AM
Yes, exactly. You will need at least 8 GB.
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
05-17-2013 07:52 AM
Also, someone has a doc of best practices on this,
I will be so very helpful,
thank you very much.
05-17-2013 07:53 AM
Hi Juan,
CUCM first insert the new one and then replace the older.
05-17-2013 09:20 AM
Hi Lesalcie
you mean "then erase the older", right?
So in my model, I will require 8GB for a scheduled backup with 3 copies maximum, right?
Won't work 7 GB?
regards.
05-20-2013 05:43 AM
05-20-2013 08:33 AM
Very useful answer Leosalcie, Thank you.!
