telephony-service unavailable router 881
KS3
Hello.
I tray configure VoIP in my network. I don't found command telephony-service.
I use router CISCO 881.
On bottom is version mu soft.
Please help me.
Kind Regards.
6 Replies 6
R0g22
12.4 is not supported. Upgrade to 15.X. Next, only 881-V supports CME. What do you have ?
Thank you for your ansewer.
How I Can update mu software. Can you help me?
Kind Regards.
R0g22
I don't have 881-V. I have only 881.
R0g22
Probably won't work. 881-V is the specific model to support Voice. IOS is different as well. For example there is a 881-Sec which cannot do voice. There are hardware differences as well.
M02@rt37
Nipum is right.
Look this doc:
https://www.cisco.com/c/en/us/products/collateral/routers/887-integrated-services-router-isr/data_sheet_c78_459542.html
C881 only is a data model.
You need C881-V for Voice model.
Best regards.
If this helps, please rate.
Ben
Best regards
