Tertiary TFTP Server
swilly1979
Level 4
Level 4
If I were to configure a Tertiary TFTP server via DHCP Option 150 for particular Voice VLANs, will the phones add the third TFTP server to their configuration file?  Thanks.
clileikis
Level 7
Level 7
Hi Sean,
From the CUCM System Guide:
Cisco Unified IP Phones use the option 150 value as the TFTP server IP address when Alternate TFTP option is set to No. You can assign only IP addresses as Option 150 values. A maximum of two IP addresses get used, and only the first two IP addresses that the DHCP server provides get accepted.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_0_1/ccmsys/a02tftp.html#wp1080018
HTH,
Chris
That's what I was looking for.  Thank you for the quick response.
Glad I could help and thanks for the rating!
Chris
