TFTP file management
sheraz butt
Hi all,
   I need edit this file
admin:file
      file check
      file delete*
      file dump*
      file fragmentation*
      file get*
      file list*
      file search*
      file tail*
      file view*
file: file dump tftp /english_united_states/SCCP-dictionary.utf-8.xml
and i need change this
<phrase i="119" t="Your current options"/> to my company name how could i do taht
CCM version is 8.5.1 check th attachment
Sheraz
gmgarrian
Level 4
Level 4
Download the file, edit, then copy it back up.
I don't think you can edit the files within CUCM.
htanay
tftp -i GET SCCP-dictionary.utf-8.xml
Edit
Remove the original from TFTP file management
Upload from TFTP file management
Dear Harsh ,
   I did understand second part which is quit simple but but dont understand the first one.
tftp -i GET SCCP-dictionary.utf-8.xml were should i give this command this is CCM 8.5 not cme can you please explane more.
Thanks in advance
Harsh is saying to download the file using a TFTP client.  The syntax provided are for a windows command line.
