The phone speaker button light automatically when I pick up the handle to answer a incoming call.
yuexp0929
Hello All
   I met a strange issue.  Please tell me if you have any advice. Thank you in advance !
    Call manger version is 10.5.2 . Phone is 7941.
    The phone speaker button light automatically when I pick up the handle to answer a incoming call.  The call will disconnect when I press the speaker button.
    I am not sure that is hardware problem .
Rob Huffman
Hi there,
This issue shows all the signs of a very common problem with the "Hookswitch" mechanism on this model of IP phone. Over the years, the 7941/61 series, have been notorious for ending up in this state where the phones no longer answer when taken off-hook and instead default to the speakerphone. Here are some links, posts, video and the Bug that details some cleaning and replacement part fixes for this problem;
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCsa93619
https://supportforums.cisco.com/discussion/10857716/7961-onoff-hook-issue
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-ip-phone-7900-series/45283-hook-switch.html
http://atc.go0se.com/?p=1034
https://www.youtube.com/watch?v=B5BSjNKkEWY
Cheers!
Rob
