04-25-2011 01:13 PM - edited 03-16-2019 04:40 AM
Hello Every one.
I have a question. My customer wants to use his company certificate in cisco call managers and unity for authentication.
It is possible to do that and wich would be the procedure for that.
Thank you for your help
04-25-2011 02:54 PM
Yes, this is possible... the procedure should be similar to this depending on version:
Under Cisco Unified OS Admin go to Security > Certificate Management...
1. Generate a new tomcat CSR, download it and send it to the CA for approval
2. Request a copy of the signed certificate along with the Root certificate for the CA
3. upload the CA root certificate as typy tomcat-trust
4. upload the signed certificate as type tomcat specifying the previously uploaded tomcat-trust certificate.
5. restart the Cisco Tomcat service
04-27-2011 12:58 PM
It is posibble to use
the same certificate for all the cluster?
04-27-2011 01:16 PM
No, you will need to create a CSR for each server and have them all signed by the CA... the server will not accept a certificate which it did not generate the CSR for...
