third party sip registering
dufour001
I buy a new voice router ISR4431 with ccme 12.0
Before that, I have old router, and all is working fine.
On nes router SCCP phone and SIP cisco phone are ok.
But i'm not able to register third party SIP phone (2N interphone)
I tried with exactly the same config (voice register dn,voice register pool, voice register global) on the old router, is registering is ok.  ... but not on my new ....
here my config :
 mode cme
 source-address 192.168.101.2 port 5060
 max-dn 800
 max-pool 300
 authenticate realm all
 timezone 23
 time-format 24
 date-format D/M/Y
 dialplan-pattern 1 6969119. extension-length 3 extension-pattern 25.
 tftp-path flash:
 file text
 create profile sync 0628093284913337
 network-locale FR
 user-locale FR load CME-locale-fr_FR-French-10.5.3.0.tar
voice register dn  8
 number 803
 name 803
voice register pool  7
 id mac 7C1E.B301.0235
 number 1 dn 8
 dtmf-relay rtp-nte
 username 803 password 803
 codec g711ulaw
and attached, the log of debug ccsip messages (IP of phone is 192.168.101.222)
Can you find a solution ?
Thx
I finally find the solution.
We must do the authenticate with register + username/password.
But for that, we MUST delete the "id mac xxx" tag. et set the id to device-id-name
same that newer version of ios can authenticate via mac address for third party ...
So, we must completely delete this.
9 Replies 9
Rajan
just looked at your post, it seems like you are missing the type command in voice register pool. its mandatory for sip phones registration. can you try adding it under.
type XXXX(replace with phone model)
Rajan
Pls rate if helpful
it's third party phone.
so, what type ?
Can you add "authenticate register" in voice register global and make sure that the user name and password is matching on the 3rd party sip phone with the one configured in CME.
Rajan
Rajan
my bad. i just see its a third party phone. so type is not required.
Not better with authenticate register, and username/password
Thanks for sharing the solution. Pls mark this thread as solved
Just to provide an example.   I had a config that looked like this.
voice register pool 4
id mac 0000.0000.0000
number 1 dn 4
dtmf-relay sip-notify
username 1122 password 3344
and it needed to change to
id device-id-name 1122
number 1 dn 4
Yes, It works now very well by this commend:
id device-id-name XXX (Same Phone Number)
specially after upgrading the CME to 12.1
Thank you gentlemen for your Nice support :)
