Time period and call forward
ivan aguilar
Hi!
I need to configure in a CUCM a time period, in witch after 18:00 pm need to be forwarded to other telephone.
I know how to configure a time period, and time schedule, but how I configure the forwarding after hours?
Thanks!!
Harmit Singh
Hi Ivan,
I agree with Jaime. There are several docs out there which can help you out. Here is one which I had bookmarked and is very helpful:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080a7bc96.shtml
Hopefully it does the trick for you :-)
Harmit.
6 Replies 6
Jaime Valencia
If you already know how to configure ToD, you just need to configure the element which is going to be active afterhours with that forwarding behavior.
If you don't, there are plenty of posts and some videos on TOD on CSC, just take 2 minutes to search and you'll find them.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Harmit Singh
Hi Ivan,
Harmit.
Ok thanks a lot!
regards!
Anytime my friend :-)
Harmit.
One question about this issue.
With this link
show how to configure schedule time and period, but the last step is how to make a call forward after hours, from 9:00 to 18:00 in office A must receive all calls, and after 18:00 hrs must to be forwarded to office B.
Thanks.
Hi all,
I need to place a call to a router and after 18:00 pm be forwarded to other telephone, so the forward will be done by the CUCM.
These are the steps i did, could anybody say me if this would run???
1- create time period
2- create time schedule
3- create a partition and put the time period created
4- create a CSS and put the partition
5- in the inbound Gateway CSS, i put that CSS
6- create a TP as ´xxxxxxxxx´ associated to DN with a CFA to the telephone to be forwarded.
Is ok? or need to add anything??
Thanks!!
