to check the status of cisco gateway 3945
karthik ratna
Hi all,
Can you please share the commands to check the status of the gateways.
As yesterday E1's was down, so verified by using show log | i Oct 22, show log | i down did not find any downtime, is their any commands to check the rootcause.
Please help me on the issue.
Karthik
Jorge Armijo
Level 4
Level 4
Well, if you need to check the E1 interface you can use "show controllers e1"
If you want to check the ISDN layers, if it's a ISDN circuit, you can use "show isdn status".
It depends on what you have on that Gateway.
Let us know what is the setup you have.
Jorge Armijo
Sent from Cisco Technical Support Android App
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Hi Jorge,
Thanks for your reply!!!
Please share the commands how to check the gateway interface status for previous days.
Did you tried show controllers E1
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
