01-09-2011 06:28 PM - edited 03-16-2019 02:46 AM
Hi all,
We have recently deployed a simple CCME+CUE router and ASA firewall for a client.
Apparently all calls are made through 4 FXO Anolog lines to the Telephone provider.
No Sip/h323 ITSP or etc.
My client is cautious about their analog lines being hacked to make international calls.
Is there any hardening steps that i need to make on the CCME router or ASA firewall to prevent this?
Since there is no SIP/h323 services on the network.
For prevention would it be appropriate if i were to block all incoming SIP 5060 port at the ASA firewall?
Please advise
Regards: Jocelyn
01-09-2011 06:33 PM
Any firewall or nat router blocks incoming connection by default already.
For more information on the subject, use the search box her or on cisco.com.
01-09-2011 07:03 PM
Thanks for the info;
I would have thought so, as firewall has implicit deny on every end of rule.
So does it mean that without doing anything else i am safe from Toll fraud at this point?
I have read that it is advisable to upgrade the IOS to 15.1(2)T since it has a Toll Fraud Enchancement feature?
I am currently running Version 15.0(1)XA.
If so; is there a cost incurred in terms of licensing to upgrade to 15.1(2)T from 15.0(1)XA
Regards: Jocelyn
01-10-2011 04:52 AM
You don't need improved security because the device is not reachable from the Internet.
The same security would be obtainable alsowith any other IOS version.
For updates, you need a smartnet contract.
Please remember to rate useful posts clicking on the stars below.
01-10-2011 06:38 PM
Thanks again for the clarification
I came across an article about UC500 breaching via the CUE voicemail module instead of WAN facing
http://community.spiceworks.com/topic/111962?page=1
Am i also safe from this breach given that i have an ASA firewall facing WAN
