06-21-2012 08:20 AM - edited 03-16-2019 11:47 AM
Does anyone know of a way to get the total number of voicemail in unity, The built in unity reports give you mailbox size but that includes all voicemail number.
Thanks much.
Solved! Go to Solution.
06-21-2012 08:39 AM
Hi Curtis,
For Unity, the reports section of the Message Store Manager tool probably has
what you need here (it is very good)
http://www.ciscounitytools.com/Applications/Unity/MSM/Help/MSMConsoleHelp_ENU.htm#_Toc110930104
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
06-21-2012 08:39 AM
Hi Curtis,
Cheers!
Rob
06-21-2012 08:47 AM
Thanks Rob,
Do you know where I can download that tool for unity 8?
06-21-2012 09:03 AM
Hi Curtis,
You will find it here
http://www.ciscounitytools.com/SiteList/AllDownloads/alldownloads.html
Cheers!
Rob
06-21-2012 11:04 AM
Thanks much, unfortunately that tool doesn't support unity 8.5 but I found this tool "user data dump" can do the job for unity 8.5:
http://www.ciscounitytools.com/Applications/CxN/UserDataDump/UserDataDump.html
cheers,
06-21-2012 11:34 AM
Hi Curtis,
Good stuff my friend
Don't forget that there are 2 separate products here, Unity & Unity Connection
so you have to keep that in mind when looking for solutions. We run Unity Connection
as well and absolutely love CUDD and many other great tools from the awesome Unity Tools
suite. Check some of these out as well...wonderful!!
http://www.ciscounitytools.com/Applications/CxN/ATM/ATM.html
http://www.ciscounitytools.com/Applications/CxN/PortStatusMonitorCUC7x/PortStatusMonitorCUC7x.html
Unity Connection Bulk User Delete
For resetting users you have the option of emptying the mailbox, resetting greetings, deleting voice names, resetting passwords, removing private lists and a number of other options you may choose. For installations where the user base “changes over” frequently such as schools this may be a nicer option. This option is also allowed for CoRes installations since it does not involve the removal of user objects from the Connection database.
http://www.ciscounitytools.com/Applications/CxN/BulkUserDelete/BulkUserDelete.html
Cheers!
Rob
